Home > Maintenance & Modifications > can I use a Bosch 072 as a leisure battery
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
As title says, can I use a Bosch 072 as a leisure battery? it is a stock standard (recommended size) battery, and do both batteries in a dual battery system have to be the same? Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #210813 12th Feb 2013 8:56pm
VeeTee
Netherlands
No problem, I have the same battery as a domestic battery. If the batteries are separated by a battery management system / VSR (voltage sensitive relay) or the like, they do not have to be the same.
In case you connect batteries in parallel (to have more capacity) it is best to have the same make / model and age (preferably both new from installation). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #210972 13th Feb 2013 4:58pm
taffrican
Thank you VeeTee, very much appreciated Thumbs Up Optimists say the glass is half full..
Post #210974 13th Feb 2013 5:04pm
Bear in mind that the majority of battery management systems and all VSR's do not actually keep two batteries separate. When operating, the two batteries are connected in parallel and are charged as if they are one big battery regardless of type or size. Where they are kept separated is when starting, as they typically rely on the alternator producing the correct voltage before connecting the starter to the second battery.
An 072 battery is probably not ideal if used as a leisure battery. It'll work, in that it will provide 12 volts when the engine isn't running, but it won't do so for as long or as reliably as a true leisure battery would. The two types are constructed differently to release their power at different rates. Darren
Post #211010 13th Feb 2013 7:09pm
