![]() | Home > Maintenance & Modifications > Help sourcing nuts and bolts for Warn CEXD9000i winch |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
ryders
otter-spotter Member Since: 11 Feb 2013 Location: Scotland Posts: 37 ![]() ![]() |
Blimey, that was quick - sorry, don't know ryders, where are they? I'm not tight, I just need my money for diesel ![]() |
How about http://www.devon4x4.com/index.php?page=sho...;Itemid=14
They just look like M8 bolts with a square roofing bolt nut. Are there no fasteners suppliers close to you? |
They look perfect - I'll get on to those. They didn't come up on any of my searches. I did find some square roofing bolts locally but they didn't have a tensile rating. 300 TDi 110 CSW |
Roofing bolts are hardly likely to have a decent tensile rating on them. I believe Gwyn Lewis has the correct Bolts
Brendan |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 665 ![]() ![]() |
It's only the nuts that are square, grade 8 should be easy to source, then just normal HT 8.8 bolts, again you should have no problem sourcing these locally.
Cheers Steve |
The way a winch is mounted there will be no stripping of the bolts it would be a shearing force on the bolt. The nut is just holding the bolt in position so it's the bolt is where the tensile strength is needed
Thanks for all the help and advice - I think I'm sorted now! 300 TDi 110 CSW
