Home > Puma (Tdci) > Back to dealer tomorrow |
Sounds about right....Expect to swap them out again if you've enough warranty left....
From another thread:
Hope this helps..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Feb 2013 7:32pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Rusty door stays, door stays not holding the door, dome lights full of water / condensation, flaking paint to wing mirror arms, general leaks through body panel foam seals, leaks through floor plates (damp carpets!), noisy / squeaky door locks, rusty door hinges, leaking grease on swivels, loose heat-shield / bolts missing, squeaky clutch pedal.
These are all the issues I have come across on my 11MY. |
11th Feb 2013 7:38pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Mine goes in next week for the same issues, I had to fight for rear mudflap brackets last time the same place had it and have already told them I don't expect the same hassle again. Interestingly the LR service place who carried out the last service replaced all the bits I requested without question - I would have gone back to them this time but they don't have an LR approved body shop so wouldn't be able to do the corrosion around the screen that has appeared in the interim. Steve.
11th Feb 2013 7:41pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Is that Lindacre Steve? They just did my second service, and excellent service as usual. Pete |
11th Feb 2013 8:58pm |
No Pete, Marshall's in Bury, it's a lot closer for me than than Lindacre. TBH since they shut down the dealership I'd forgotten about Lindacre's still having a service bit. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
11th Feb 2013 10:02pm |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
Thanks or the replies, the swivels are leaking and it's already booked in for that, not great considering they only did them 6 mths go!!
As for leaks I only have a minor one just in front of the NSF wheel arch. All paintwork is immaculate still......... I thought if I get it done now I still have another 15mths of warranty to change them again before it runs out Darren |
11th Feb 2013 11:10pm |
