![]() | Home > Maintenance & Modifications > ScanGauge 2 |
Very simple and incredibly useful
![]() Edit - anything specific you want to know? I use mine mostly for watching real time fuel consumption (helps me drive "sensibly"), battery voltage, intake temperature etc. I use it for clearing the error codes/light when I'm experimenting with e.g. the EGR valve. Also lets you know how far you can drive until empty (useful on long trips). Plugs into the OBD interface - I cut a small neat hole in my fuse box cover (as it sticks out a little) and have it sitting on the steering column cowl just in front of the instruments (Velcro). Some members have unscrewed the interface from the bracket so it pushes back a little. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 11th Feb 2013 9:18pm. Edited 1 time in total |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
X2 - my Puma is still being built, but I slung a Scanguage in the Passat in the meantime. Great bit of kit... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Good for the price. Mind you a cheap E-bay tool would do DTC jobs the same but the ScanGauge is Live I believe so has much more usability. WeWillWin🇬🇧🇺🇸
Loads on here using 'Scangauge' as the keyword......
![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Aahhh - but would the E-bay tool have a decent sub output? Speaking of o4dn (as he is now known), we both realised how important it is to re-calibrate the fillup volume a few times before relying on it. Scangauge "learns" how to deal with inaccuracies. It's really important to re-calibrate after a remap. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
