![]() | Home > Wheels & Tyres > Fatter spare tyre will encroach rear wiper |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Mate fitted 255/85s to his and it touched the wiper arm. Someone mentioned spacing it out but in the end he put a slight bend in the wiper arm and that was enough to clear it.
Have you thought about a spare wheel carrier...... then you can put a bike chain through the spokes of the wheel and the frame of the carrier...... it will also reduce the stress on the back door which can cause problems if you do regular off-road, and it will move the tire away from the wiper ![]() Glyn ![]() ![]() |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1235 ![]() ![]() ![]() |
I have a 265 as a spare.
The wheel carrier is adjustable. 3 large nuts which you can wind out to give you the 5-6mm you need. I took the nuts completely off and put spacers behind them. This elliminated the wheel "shake" as you shut the back door. Securitywise a plastic coated chain and good lock, in addition to locking wheel nut. Check out my Gallery ![]() Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
I'm sure I put this up only a few days ago for somebody asking the same question. Ho hum - three standard steel wheel nuts behind the large flat nuts works a treat:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
hmmm
i have the 18" silverline wheels that don't stick out of the arches and the rear wiper arm just rubs on hte spare. all i did was slacken off the three nuts holding it on and then wound out the top large nut on the wheel carrier by about 3/4 of a turn and then tightened up the three wheel nuts. with a little bit of trial and error you can get an exact fit just by adjusting the top one. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
4mm washer will suffice.
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I have a BFG 255/85 spare on my back door (on standard U bracket mount). On a modular 16" steel rim, with cover on, there is still plenty of space. In fact more than the 235/85 on boost alloy that it replaced. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
He had them on standard offset 'Deep dish' alloys- modulars will probably be 30mm offsetted compared to LR wheels. The 10mm extra width meaning it will move 20mm away from the wiper where just fitting the 255s to standard wheels will move it 10mm closer..................and I have just gone cross eyed trying to put that into words Glyn ![]() ![]() |
My wiper is bent,
![]() If wheel spacers are going to be fitted, I guess an extra one (if they can be bought singly) for the spare would solve the problem. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
They are pretty heavy things, not sure I'd put one on the carrier along with a wheel. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 255 ![]() ![]() ![]() |
Thanks for the replies. Didn't realise the bolts are adjustable. Can easily fit without further additions. Like the thought of the shake eliminated though so may end up putting a washer in there to stabilise it. Don't think I will use a wheel spacer though, I'd rather spend the money on something more practical - like a few pints in the pub!
Your bolts might not be adjustable Egg. They aren't on the newer ones. It'll save a bit of bother if they are. Otherwise some big 4mm washers will be fine.
