Home > For Sale & Wanted > 10AS box.
RED-DOT
10AS box.
Wanted to try or buy a green 10AS box for a 2008 Puma XS. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #209946 9th Feb 2013 8:18pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Doesn't a 10AS box have to be 'matched' to the ECU? That is to say you can't just chop and change, you have to program one to match the other.
Andy.
Post #209958 9th Feb 2013 8:57pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
The programming is easy. Takes about 5 min to copy file, reload and sync fobs. Takes longer to unbolt 10AS.
Steve
Post #210059 10th Feb 2013 8:49am
Lorryman100
A new or known working AS10 will need to be learned. The process for the Puma is called DDS learn and can take up to 30 mins to complete. Then a relearn of all key fobs will need to be done before they can be used. Thumbs Up
DDS learn procedure, enable DDS learn in diagnostic tool, remove diagnostic tool from OBDII socket and switch on ignition, the immobilizer light (IPAC) will flash rapidly during the learning process, once the learning process and synchronisation is completed the immobilizer light will stop flashing and the horn will sound briefly. Job done.
Post #210117 10th Feb 2013 11:39am
