Home > Off Topic > FAC shotgun advice
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
FAC shotgun advice
Ive held a shotgun licence for about 8 years with no problems and i have access to over 1000 acres of farm land and woodland that i use now my question is what do i have to do to be able to buy a FAC shotgun how do i aquire the licence as its a bit different to just FAC licence i dont want or need a rifle so im a bit confused
Any info is greatfully received
Post #209091 6th Feb 2013 10:01pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Post #209093 6th Feb 2013 10:04pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I, personally have no idea, but this link might be helpful.
http://www.bushcraftuk.com/forum/showthread.php?t=28792 Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #209096 6th Feb 2013 10:10pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
All the info and help is here, www.basc.org.uk. _______________________________
Puma Defender 90
Post #209110 6th Feb 2013 10:38pm
Delskinz
England 2007 Defender 110 Puma 2.4 SW Tonga Green
You apply for the Section 1 license as if you were applying for a rifle but in the application write FAC shotgun instead, the process is the same. You need to give your reason why you need it over a standard shotgun plus references etc.
Post #209113 6th Feb 2013 10:48pm
Also speak not email to your assigned firearms rep at the issuing force, they can be a wealth of information Thumbs Up
Post #209117 7th Feb 2013 4:53am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
If you need any help then get on a forum called pigeon watch, very helpful info on there plus your usual forum trolls Whistle
Post #209120 7th Feb 2013 7:29am
smb
Stupid question, but why do you need a "FAC" category shotgun? You need to come up with some pretty good reasons to have one! You then need to find someone who is willing to sell one to you.
Basically, you have a "Firearms Certificate" for the obvious and a "Shotgun Certificate" also for the obvious. If you want both you can apply for them to be renewed at the same time to help you forgetting one or the other. This is a "Cotorminous Certificate".
However, If you want a shotgun that is designed to be 'rifled' or can hold more cartridges in a 'magazine' then this is out of the scope of a standard shotgun certificate, but does not necessarily fit within that of a "Firearm Certificate". As it is classed as more 'dangerous' than a standard shotgun you have to apply using a Firearms Certificate Form.
We have the Censored from the Hungerford massacre to thank for this... and lately the Censored one in Cumbria.
The Firearms Application form is a lot more onerous and you will have to give permission for checks to be done via your doctor. Also, Landowners permission, different category of witness, etc...
I may not be a 100% accurate as different areas have different views and opinions.
Which are are you in? I would speak to the inspector who granted you your SGC.
Post #209146 7th Feb 2013 10:40am
I think that you also need a FAC to use solid (rifled) slugs in a smooth-bore shotgun... though I am not really sure why you'd want to do this in the UK.
The FAC application form is used for various guns which don't readily fit into other categories, for example veterinary dart guns, which are large-bore compressed gas guns firing a projectile which amounts to a syringe, but they fall under the restrictions due to the high muzzle energy. Most of the questions on the form are irrelevant, but the form and process still has to be used.
Post #209153 7th Feb 2013 11:11am
smb
Very true, too Thumbs Up
Unless you really need it, and you will certainly be asked why you do. It's not worth applying as if you get rejected it will be flagged up in the future. Everything you do like this ends up in one big data storage centre in Mid-Wales for future reference......if you know what I mean Whistle !!!
Post #209155 7th Feb 2013 11:28am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Its a section 10 that you need to have for a shotgun with a capacity of more than three cartridges. As suggested speak to you local Firearms officer, they will put you straight. (or a rifled barrel with solid slugs, but not sure you'd get that , or have a use for it!)
There are several who have these at my local gun club, I believe that vermin clearance is a valid reason to own one.
One guy at the club has one of those Russion made Saiga multishots that look like an ak47 with a big magazine below - scary looking stuff Shocked http://en.wikipedia.org/wiki/Saiga-12 Not quite sure why anyone would want one of those but each to there own. A nice multishot auto would be ideal.
Good luck with that, shouldn't be a problem as you have the land and most likely justification for ownership.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #209158 7th Feb 2013 11:39am
Happyoldgit
Very true, although they do vary a bit I found it's always worth spending some time building a good relationship with these guys Thumbs Up Steve.
http://forums.lr4x4.com
Post #209165 7th Feb 2013 11:57am
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Don't let people put you off applying for your needs. Speak to your local Firearms division-they are the ones who know what they are talking about.
If they are anything like the guys at Openshaw-you will be impressed by the way your application is conducted.
Post #209396 8th Feb 2013 2:34am
