Home > Maintenance & Modifications > Putting in Heated Seats..Puma |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
It is a more complicated wiring job...
A poverty spec will not have the wiring for the seats... so you need to sort out making up a wiring loom as well as fitting the switches. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
6th Feb 2013 8:44pm |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Complete looms do come up on eBay, but then you've got to fit it - dashboard out job. I bought one recently to add heated seats and screen - works out cheaper than a seperate loom and timer from eBay, but a bigger job to fit. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
6th Feb 2013 8:50pm |
Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82 |
I recently purchased a heated seat kit and have partially fitted it to my 2009 2.4 Puma; the drivers side is temporarily plugged into the cigar lighter while I contemplate how to wire it in. I purchased from a Landrover dealer (MJ Fews, Charfield, Glos) last Saturday two heated seat switches and from eBay the black plug connectors. I found a thread here http://www.defender2.net/forum/topic10705-180.html which shows the plug wiring detail. I also purchased a fuse box which I have installed under the drivers seat which I intend to use to power via relays (part of the heated seat kit) the heated seats. The heated seat kit came with the round switches - I didn't fancy cutting holes in my Landy just yet ( only had it a few months ) that's why I acquired the ' proper' ones. I'm in no rush to wire it in as its working ok from the cigar lighter - need to wait till it warms up outside first (but then I won't need them!)
6th Feb 2013 9:31pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1218 |
Thanks
All understood. Will get genuine LR switches and seek advice on loom and connectors. Hope it's all worth it! Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
6th Feb 2013 9:43pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
I am just about to do this to a poverty spec, does anyone have MPN for the looms required or make them up? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Nov 2015 10:30pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Mobile centre sell the complete wiring kit inc switches for about £130 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
11th Nov 2015 11:12pm |
thank you, ! i have the switches already so just need the loom or MPN for the plugs for the switches and the seat elements. Cheers
11th Nov 2015 11:13pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
There's no LR part number for the loom alone, it is integrated into the body wiring loom (or not).
Pretty sure Mobilecentre will supply without the switches. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
12th Nov 2015 11:12am |
ok, thank you Cheers
12th Nov 2015 11:05pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
We have a complete plug and play loom available on our website, no crimping, no soldering, comes complete with genuine switches, everything you need - www.fcx.co.uk
13th Nov 2015 6:35am |
ok, cheers, will have to think this one through a bit, maybe wait until its colder to make my mind up! Cheers
13th Nov 2015 10:53pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
I have the kit from FCX, very good it is too and works perfectly and looks completely factory.
Combined with Waeco heat pads. |
13th Nov 2015 11:03pm |
