![]() | Home > Puma (Tdci) > Twin Odyssey Battery system |
Any recommendations needs to fit a D44 Tray
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
2 1500`s and a D44 tray fit well and then a simple split charge is the Bep Marine 300amp relay that Devon sell
Cheers I'm in ultra lazy mode will I need to fab up connectors
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
Sonic, when we spoke about this mod, you mentioned something about a cool way to attach the main alternator feed wire to the +postive battery terminal, on the main battery
I used the OEM fused terminal, hung over the 1500 battery in a different postion to stock, but had to take the back cover off, seemed somewhat a bodge... ![]() interested to know if there is a better solution cheers... |
Devon state on the web that the D44 tray is not compatible with the OEM battery ![]() |
Cant find that one this any good ? http://www.devon4x4.com/products_a/p929c36...-300a.html |
It is possible to fit two 1700 Odyssey batteries with a Devon tray but tray needs a slight modification if fitting the 1700's transversely
Brendan |
