  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Puma (Tdci) > Clunking noise when slowing down
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
As title, a clunking noise which has become evident on my 2013 110 XS as I slow down. I think it is more evident when I dip the clutch and hold it down coming to a halt but I cant be sure. Tried to recreate it, but it does not happen all the time. As it doesn't happen all the time its difficult showing symptoms to (German) dealer!
Any thoughts at all?
Steve
Post #208291 4th Feb 2013 2:40pm
Laurie
Check your propshaft UJs and flange joints for slack.
Post #208293 4th Feb 2013 2:53pm
jst
if its after a longer run could be the handbrake binding, is the drum warm? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #208294 4th Feb 2013 2:55pm
borderterrier
Thanks I will, I would not have expected them to be loose after 3000 miles, but I suppose it is a LandRover!!
steve
Post #208295 4th Feb 2013 2:55pm
borderterrier
Will check that too - thanks
Steve
Post #208296 4th Feb 2013 2:56pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Most likely hand brake, next time try gently lifting hand brake lever a little bit, noise stops = Handbrake. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #208300 4th Feb 2013 3:26pm
borderterrier
Thanks Willy Very Happy
Steve
Post #208305 4th Feb 2013 3:46pm
excossack
On my TD5 I got clunk clunk clunk when coming to a stop. It was oil on the drum causing the brake shoes to bind coupled with handbrake adjustment. After fixing the leak and adjusting the shoes all is well. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #208314 4th Feb 2013 4:18pm
