Home > Puma (Tdci) > Ply Lining
Dieselhead
Ply Lining
I want to ply line the rear of my 110 Utility
Has anybody else done this?
I need to know the best way to attach ply over the plastic mouldings without recking them
Just looking at ideas before I crack on with the job Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #207957 3rd Feb 2013 11:57am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Probably easiest to take the trim panels off - to fix ply to them, you'd have to drill holes or use adhesive - both damaging. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #207965 3rd Feb 2013 12:09pm
Killer90
Site Sponsor
perhaps you could try sticky back velcro or the likes of the really sticky numberplate double sided tape Thumbs Up or the other way is drilling and self tapping Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #207992 3rd Feb 2013 1:35pm
Dieselhead
Dont think sticky tape will hold up to the job
I think my best bet is to made up an internal frame of metal angle which I will weld up & then bolt it in through the wheel arches.
The wooden interior will then be attached to that Thumbs Up Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #208064 3rd Feb 2013 6:02pm
doberman
United Kingdom 2012 Defender 110 Puma 2.2 USW Galway Green
Hi when I did mine I removed all of the mouldings so that it maximised space and was easier to soundproof, all the fixings I did were with self tappers so I could get a really solid non squeaking job done, plus I doubt it will be ever remove when I sell it as its a good base for anyone to do with whatever they want to use the vehicle for. I'm not telling anyone how to do it but I do know that whatever adhesives you use they will after time let you down, because we have so many differences in our temperatures. Good luck
Post #208125 3rd Feb 2013 9:08pm
jst
i covered some ply in vehicle carpet and then pushed them in behind and around the trim for the sides. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #208142 3rd Feb 2013 10:01pm
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Do you gain much space taking off the trims?
I was thinking of putting some thin foam behind the ply to stop the trim being damaged and to add a bit of soundproofing....
Post #239880 31st May 2013 8:12am
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
When I did mine, I made it so most of it was fixed to itself. An only top of the side sheets is screwed th the trim with very small self tappers + stuffed bubble wrap behind it all to adsorb vibration and sound. Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #240081 31st May 2013 8:27pm
