Home > Maintenance & Modifications > Rock sliders. |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Thud, you normally remove the original LR Ali cill completely from the vehicle to fit rock sliders.
Brendan |
3rd Feb 2013 8:38am |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Yes, I guessed. The question is will the sliders cover the checker fixing holes with either brand? |
3rd Feb 2013 8:40am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
You normally remove the lower sill panel too.
3rd Feb 2013 9:03am |
I see. That makes sense.
3rd Feb 2013 9:37am |
Well they look great on your very nice truck GM. True about the galvanizing. Probably worth the £100 in the long run.
Swinging towards Safari Equip now. Are they in stock Brendan? (The version with Nerf bars) |
3rd Feb 2013 10:08am |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Not on the site exterior products>protection...yet. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
4th Feb 2013 10:29pm |
Just spoke to Ian at Richmond. Seems like a good chap. Promised delivery within two weeks.
5th Feb 2013 9:32am |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
Could anybody do me a big favor and post up dimensions of the 110 versions you have.
Especially where the mounting points are. I am going to build my own and this will save me a lot of time. Not that i don't want to buy any but i need to incorporate brackets and holders for my water tanks and skidplates, so not much sense in buying something and then grinding off the powdercoating; much appreciated! |
5th Feb 2013 11:22am |
rusty66 Member Since: 22 Jun 2010 Location: Rhineland Posts: 60 |
Hi,
I've just made my own. It's better to fabricate the sliders and the brackets separately and then fit them on the car. Building tolerances make it difficult to align the sliders nicely without 'trying them on'. Also there are some treesliders (if you are after these) that have three little struts between bar and slider and others have only two. I think three look nicer. Some sliders have the tree bar running out to the slider box section at a fairly shallow angle (excuse my simple English). This I also didn't like that much, so instead of bending the bar I welded bends from plumbing pipe to the end of the round pipe section. Last thing that I 'changed' from many sliders I saw are the ends. Which I think look nicer with a bend and not as a straight line. I have some simple measurements that I don't dare call a technical drawing, but they might help. I do also have some pictures if you are interested. It's a bit late tonight but I could upload them some other time. I thought about buying, too, but first there's quite a bit of fun in doing them yourself and they also came much cheaper at about 30 pounds for all the metal section I needed. Of course there'll be galvanising and powder coating, but at least then you know it's been well done. Good luck with your project Sorry, technical English is as bad as my ability to do technical drawings Boris Click image to enlarge |
6th Feb 2013 10:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17380 |
Although it doesn't include dimensions, you might find this link useful:-
http://www.paddockspares.com/media/downloa...PM1069.pdf |
7th Feb 2013 10:07am |
Safaris have 2 http://www.safari-equip.co.uk/index.php?page=49
Terrafirma have 2 http://www.terrafirma4x4.com/products_php.php?cat=80&grp=114 Richmond have 2 http://www.rock-sliders.co.uk/landrover-de...iders.html Sooo, who makes them with 3? More/same on ebay: XRT http://www.ebay.co.uk/itm/Rock-Sliders-Lan...3a7d77d412 4wheeln http://www.ebay.co.uk/itm/Land-Rover-Defen...2eb30e39c5 CCRC http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...417013892a Stanbra http://www.ebay.co.uk/itm/LANDROVER-DEFEND...1c2ebd5fbb wellspacedout http://www.ebay.co.uk/itm/Land-rover-defen...35bf1e32d9 Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
8th Feb 2013 7:26pm |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 |
Gruezi* Rusty,
Nothing wrong with your English, but if you get a chance, could you trace your drawing onto a blank sheet of paper that doesn’t have squares on it – it’s a bit hard to make out! Also, if you have pictures, I (and I suspect others) would be keen to see them! Also for the benefit of others contemplating a DIY fabrication, the Entreq Website shows some very detailed photographs of their bracketry arrangement. Make sure you’re sitting down when you see the prices though. *Yes I know that’s not the correct Rhinish greeting, but it’s correct where I grew up Real trucks don't have spark plugs |
9th Feb 2013 10:14pm |
Hi,
I will redraw the 'drawing' or try to do some work with the scan on the computer so that the squares won't show. Just need a bit of time. I can also post pictures, but the camera is still in the workshop and I won't get there until next week. There are two or three on my phone which I took to show the galvanizing company that I drilled holes in all the hollow sections to connect them. Maybe they show some other details, too. I will post them later. Yes, Gruezi is not quite what we say here in the Rhineland But as I think of it, I can't really say what we say ... The closest might be 'Mahlzeit', which is something likle "enjoy your meal" and can be used as a greeting anytime 24/7 ... But I've also only moved here about 10 years ago. Mind you, almost everyone my age downwards seems to say 'hi' these days, so we're really international here |
12th Feb 2013 8:01pm |
I cleared up the drawing. Don't really know if that made it any better. There are some measurements missing and this is my initial sketch. As I said, when I built the slider I worked with the car at hand to try and measure on the go. I haven't studied engineering and am more the practical sort of 'mechanic', so please once again excuse the lack of sophistication here.
Click image to enlarge Well, and here are some other pictures: This shows the two sliders at an early stage with the middle struts and the bent which is from ready-to-buy- plumbing pipe. This shows the end. You can see that I marked the metal to be cut off at two angles. Did a bit of trying out with a cardboard pattern until I was happy. The finished bit looks different because of the plate welded onto the ends. The struts are welded on and drilled to allow air to escape during hot dipping. This is essential as otherwise the trapped air might expand and the tube section explode with the risk of serious injury. Finally, again the ends of the tree sliders. This looks neater than bending the pipe yourself. It means, of course, more work and welding ... There are more pictures, which I will upload when I get hold of the camera. Cheers Boris |
12th Feb 2013 8:23pm |
