![]() | Home > Maintenance & Modifications > Rear Crossmember |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Took advantage of the weather this morning and treated the rear crossmember to a fresh lick of Satin Black.
Set up a timelapse too, will post that up once I've edited it. ![]() Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
That looks fantastic and makes me want to do mine.
Don't wait a year! Better to do it from new before any sign of rust would appear. Satin paint at the outside and thorough Dinitrol or other anti rust treatment at the inside should keep your crossmember as new ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Wire wool to get the small amount of surface rust off. Then some primer (normal not etching) then Satin Black.
Timelapse video will show it all......coming soon. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
OK, added to the "things to do" list. (a list that seems to get longer every day)
I've always sprayed mine from day 1 after cleaning with a good liberal coating of WD40 and periodically in between. Looks as good now as when I got it!
![]() Treat every day as if it is your last....one day you will be right!! |
Same here after more than 4 years
And stainless bolts are a must too to set off the whole fancy look.
They are also in all around the car from when it was about 3 months old
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Mine was done last September and still looks like new,
All of my ones on the crossmember are stainless except for the towing bracket fixings as they need to be a high tensile. :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Good paint for chassis / rear etc.
http://www.frost.co.uk/marine-boat-restora...473ml.html Original Member Pie n Pea Club. 110 HCPU Tipper |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Lorryman,
You might look after your Cross Member but you don't weed your driveway ![]() Steve ![]() Discovery 3 HSE BMW 330i Coupe |
They get buried once a year anyway when I add a couple of tons of red chips, easier than raking them back from my neighbours driveway.
Timelapse from earlier!
http://defender2.net/forum/post207787.html#207787 Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
