![]() | Home > Puma (Tdci) > JW Speaker 8700 LED Lamps MOT Failure |
I can confirm Tim is on the mend and intended to be back "at work" today (albeit very gently, I'd imagine). Kudos to Toni has been doing a terrific job holding the fort at Mobilecentre in the interim. It's great to have such people looking after our needs and wants
![]() If the NS light only failed on height adjustment, it can't be an "approval" problem with the lamp design as a whole. I would suggest it may be harder (perversely) to adjust the 8700s for MOT testing than the original lights. The original light pattern is quite diffuse so aiming allows for some "artistic license", whereas if the LEDs are even slightly out it's bloody obvious. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Oh yeah, can't see for looking sometimes ![]() I think light "spread" is one of the things the MOT people have been told to concentrate on at the moment, something to do with people fitting aftermarket bulbs that mess up the beam pattern of standard lenses. http://www.yorkshireoffroadclub.net/ |
If your mate has an mot place why not ask him to check the alignment again for you?
You're not the only person to experience this and with a little patience and time you can possibly do something about it yourself, I have no issues with mine but I treated them to a little extra sealing. Alternatively see about getting a replacement. If your's is as bad as depicted in the thread below Tim offers a replacement.....Sorted!!!!!
Thread linky: http://www.defender2.net/forum/topic7192.html?highlight=ingress If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Three questions, if I may:
1) Are all these foggy lenses made of glass? 2) How many have been pressure washed? 3) Has anyone had foggy polycarbonate lenses? I have "waterproof" Hella LED driving lights (not cheap) with poly lenses, but they fog up too ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
I think I may know where you're heading with this Matt. (I may be wrong and way off track though.) If it may be about the heat coefficiency between polycarbonate and glass perhaps?
Both lamps are I believe made the same and should effectively have exactly the same level of protection with regards to water ingress. If there's no moisture inside it shouldn't fog or condensate irrespective of what the lens is constructed from. Me personally I would always choose glass over polycarbonate due to it's resistance to extreme conditions and scratching but the price you pay of course is it's brittleness to impact damage. I did 'pose' the preference question some time ago and Tim's response was....... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Why didn't you go to your mate for an MOT? =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Think he already stated why.....
I think he did the right thing. ![]() I did exactly the same and went over it with a fine toothcombe and made a list.... I too then submitted my Landy early for it's MOT so the dealer would be obliged to sort any issues. I would probably 'visit' my mate first now though and get him to recheck alignment and beam pattern after sorting out the moisture ingress myself perhaps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
I have the same headlights and Oscar passed his MOT today with no problem or issues
