![]() | Home > Puma (Tdci) > PLY LINING |
Paul i got some ply from B & Q made my own really easy job, you only have to cut to size and drill one hole, I also carpeted mine, 1 piece of carpet and some carpet spray Simpels
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Not cheap but there is a company in the back of LRO that advertise panels for the sides for hard tops, finished very nicely in carpet. Been looking for some for mine.
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
I did my own too, got some 6mm ply and cut it to size then glued some thick foam on back and carpeted front with Black/Dark Grey cord carpet fixed with spray carpet glue. Cut rounded corners and shaped to fit curves. With the foam on the back it cuts down some drumming that you get in hard tops. It should take an afternoon
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
right thats it i think its time i tried to cut in a straight line
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 ![]() ![]() ![]() |
If you are buying ply, for the back of a landie - make sure its Marine ply, more expensive but will last better in damp conditions
