Home > In Car Electronics > £7.99 Aerial upgrade. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Cool! I assume the threaded piece you crimped on is a good tight fit, or it could part company at speed.
Pete |
28th Jan 2013 7:19pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Sweet
28th Jan 2013 7:20pm |
Nice! Can't go wrong for £7.99 An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
28th Jan 2013 7:21pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
* It's a Land Rover, if at least one part doesn't fall off per journey then it's not working as it should. *Yes, it's very tight, hence the ratchet crimpers |
28th Jan 2013 7:28pm |
Day light photo, I'm quite chuffed with this. It looks okay I think.
Click image to enlarge Last edited by Tiger on 13th Sep 2013 10:07pm. Edited 1 time in total |
29th Jan 2013 7:11pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Awesome, I love a good bodgejob!
I might give this a go on the weekend as mine works ok, but it doesn't go all the way down and get's stuck. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
30th Jan 2013 4:31pm |
Tiger!.....
Just did mine the same. I opted for a VW replacement for £3.85 http://www.ebay.co.uk/itm/270955002855?ssP...1497.l2649 Works a treat! Perfect reception! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
1st Feb 2013 6:58pm |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 |
Is that a straight replacement or is some jiggery pokery required? |
1st Feb 2013 7:12pm |
£3.85 ! - you win
It really is simple. As Tiger explained, cut/snap the original off at the last section then screw the threaded bar into the remaining aerial left over. Crimp it with cutters/pliers/crimp tool and screw the new aerial in. Push down flush. To be honest, the thread took so well inside the original aerial that it didn't need to the crimped but did it anyway. Checked the radio and FM, MW and LW all work perfect. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
1st Feb 2013 7:33pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
That looks a bit Heath Robinson to me. You lot are a load of cheapskates.
1st Feb 2013 7:58pm |
Yorkshire and proud
1st Feb 2013 7:59pm |
Welsh and proud Craig Rogers
1st Feb 2013 8:06pm |
