![]() | Home > Maintenance & Modifications > Decat pipe and wrapping it? |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Is it worth wrapping the Decat pipe with that exhaust heat wrap?
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
No! You want heat dissipation not retention! If you go through life with your head in the sand....all people will see is an ar5e!!
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
In in increased velocity will be virtually immeasurable.
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Yes wrapping will reduce heat that gets into the cab. However I have heard that stainless is prone to cracking when hot. Also ditch the centre muffler for a straight pipe.
OK thanks for the replies.
Will be doing the muffler at a later stage as i am still under warranty. (hoping they dont notice the decat) ![]() 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
