Home > Off Topic > Karcher HDS550 |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Check the flow into it.
It's restricted somewhere. |
27th Jan 2013 11:07pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Plenty flow to the tank and feed to the pump head. Friggin. Baffling. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
27th Jan 2013 11:10pm |
I had a faulty 'auto-shutoff' hoselock connector.
It worked fine on everything except filling my caravan tank and my pressure washer. Try a different connector. |
27th Jan 2013 11:23pm |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 |
I had the same issue as Laurie with an auto shut off head.
There is a little plastic cross in the connector that restricts the flow. Cut it out with a pliers and everything was fine Worth a look |
28th Jan 2013 8:03am |
I have crows foot straight through couplings and there seems to be plenty feed to pump heads. Machine reaches pressure then loses pressure when trigger is pulled. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
28th Jan 2013 10:39am |
Hi Red Dot,
Don't know if yours is the same but my Karcher must be at least 20 years old and still gives me great service. At the end of the nozzle I have what can only be described as a stainless steel reed valve which is two small flat pieces of steel that varies the water jet, when in use I have experienced when using it up close and the valve is open that grit and dirt can migrate between the steel plates and affect the nozzle pressure. If yours is the same you can either dismantle the end and flush it out or by using a small instrument screwdriver dislodge any crud caught between the steel plates. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Jan 2013 10:47am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I had this on my Karcher 620. As it stays in the garage I assumed frost had broken it. After a complete strip-down and rebuild, I found no obvious fault. When I put it back together it all worked fine again
It's the one that looks like this: Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
28th Jan 2013 10:51am |
Mine is a semi industrial hot water cleaner model HDS 550 and it was perfect prior to this problem. I have one the same as your 620 in the loft if you ever need parts? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
28th Jan 2013 10:57am |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I wouldnt use one in the loft, water might leak through the ceiling below. Ive read lots of reports of Karchers pulsing on and off, my previous one did it. |
28th Jan 2013 2:36pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
If all else fails Red dot give them a ring at their Banbury HO and ask for technical. The one you have is a pretty decent one and they will be helpful. They tend to be very unhelpful if its the standard K2, K3 etc stuff on sale at DIY stores because they know they're garbage and built to a price - and anyway the B&Q, Homebase stuff is only a fraction of their market
28th Jan 2013 8:08pm |
