Home > Maintenance & Modifications > Half width dog/load guard?
WarPig
Anyone know if there are any half(ish) width dog guards available?
I've got a full size one, but often I want to put say a long length of timber inside, and not on the roof. But obviously my dog guard restricts. I need the dog guard to protect my child who sits behind drivers seat from anything flying around in the back.
My Defender is a 300tdi, but any suppliers for the puma would be a good starting point for me.
Cheers.
Post #205272 25th Jan 2013 5:22pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
If you are talking about half height (just the top part) here's how I did it using a standard two part kit. http://www.defender2.net/forum/topic13077....=dog+guard You could probably do that with a 300tdi one, although I seem to recall it was either bulk head fixing or a full size all in one which you'd need to chop.
Not sure what you'd be able to fix a 1/2 width one to. If you have a bulk head you could use one of those lengthwise dividers and chop a full width in half, but might be a bit of a bodge unless you metal work skills are far better then mine!
Not a geat deal of help really but I'm thinking 1/2 height which is probably not what you want when you say 1/2 width.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #205278 25th Jan 2013 5:41pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
How about taking a full size one, and modifying it, making removable sections?
Post #205279 25th Jan 2013 5:45pm
BigWheels
A full width one with a "gate" modification seems a fairly easy option. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #205353 25th Jan 2013 8:56pm
NoDo$h
Exactly what i did with the full guard for the Disco. Puma 110 SW guard from Land Rover has a drop-down section where the middle seat is if that helps?
http://www.rimmerbros.co.uk/Item--i-GRID007372
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #205359 25th Jan 2013 9:05pm
I suspect that this isn't quite what you're after either but I'll offer it anyway just in case: I made a bulkhead for behind the 2nd row seats in my station wagon and then mounted a half-height guard intended for one with a bulkhead behind the front seats on top. This top part can be removed very easily if I need to carry something longer, and the bulkhead itself can also be taken out by undoing four bolts that fit to existing threaded inserts.
 Darren
Post #205419 25th Jan 2013 11:41pm
WarPig
Thanks for the replies.
I'd really like to be able to put my bike inside without having to remove a wheel. If one end of the guard was missing then i could fold down one of the end 2nd row seats and the bike would fit down one side of the 110
I guess for a strong fitting, a half width wouldn't work? I might have to butcher my full size guard but it seems a shame really.
Post #206332 28th Jan 2013 7:58pm
