Home > Puma (Tdci) > Injector learning problem.
Janhuizing
Netherlands 2007 Defender 110 Puma 2.4 SW Santorini Black
My 2007 puma is 3 days at the repair shop but they cant seem to fix the problem.
After a bad remap they brought it back to the original software.
After learning the pump to the computer they started with the learning process for the injectors.
There comes the problem, computer says " cant learn because car is in start mode"
Please help, does somebody had the same problem ?
Does somebody know what can be the problem ?
Post #204886 24th Jan 2013 9:07am
wslr
Is it using the Land Rover system SDD/IDS or Autologic or something similar?
Post #204934 24th Jan 2013 11:24am
Janhuizing
They are using autologic but after that also " original LR .." They said
Post #204941 24th Jan 2013 11:51am
wslr
I've had a couple of 2.4 Defenders in recently and my SDD was not at all happy with the engine ECU. In fact I had to set the ECU up again. Both of them had one common denominator - both had been on Autologic just prior to them having to come to me.
Can you confirm that you have the lastest SDD software running when they tried it, or were they using an old Legacy IDS version?
Post #204942 24th Jan 2013 11:56am
Janhuizing
I think so, they updated the autologic when i came they said.
They just called that they could not fix the problem !
The only thing they said was it could be a serious mechanical problem or a electronic problem....... I could figure that out.
Also said maybe the engine could be damaged seriously if i drive with it !
I dont know what to do now.
Post #204994 24th Jan 2013 3:46pm
wslr
I think you will need to find someone who has the Land Rover system and which is right up to date. Isn't there a Dealership along the motorway south og Groningen? I remember passimg it on my travels up north.
Post #205098 24th Jan 2013 9:24pm
Janhuizing
Thats right ! That is 30 km. From where i live.
The company is called Geba.
I will contact them and ask for a check.
Thanks ! I'll keep you posted.
Post #205102 24th Jan 2013 9:49pm
