Home > Puma (Tdci) > Alarm LED in dash flashing whilst driving
Page 1 of 3 123>
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Happens every now and again, very infrequent and randomly, ie not flashing with any rhythm, almost like a bulb with a loose contact - any thoughts?
Defender is a new 2.2 110 XS
Steve
Post #204725 23rd Jan 2013 3:27pm
forest172
2013 Defender 90 Puma 2.2 SW Santorini Black
Re: Alarm LED in dash flashing whilst driving
Steve
mine does this too Question
Post #204743 23rd Jan 2013 4:13pm
Mine's a 2.4 Puma and doesn't do it. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #204745 23rd Jan 2013 4:29pm
borderterrier
Dealer reckons duff alarm remote battery, I reckon not whilst driving! Keys swinging so that immobilser chip moves away from pick up around ignition barrel? Loose wire in alarm system, but seems odd that 2 cars are doing it?
Steve
Post #204758 23rd Jan 2013 5:23pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
my old 08 reg puma 2.4 didnt do this but my new 2.2 does do this..... Confused now its x3 cars, sounds like its common to the 2.2....
Post #204759 23rd Jan 2013 5:23pm
borderterrier
Post #204773 23rd Jan 2013 6:13pm
Green Machine
Sounds like a fairly typical Land Rover issue - don't test it, just sell it. Seems from the other thread that it has a connection to the radio being on/off? Maybe some of you other guys with 2.2's could try turning the radio off and see if the light goes off, which would identify the cause a bit more specifically.
(BTW - I don't have a 2.2, I have a Td5, but I'm sticking my nose in anyway). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #204774 23rd Jan 2013 6:22pm
borderterrier
Opinion most welcome GM
Steve
Post #204776 23rd Jan 2013 6:25pm
WWA
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Orkney Grey
Just had a test of mine, no flashing light when driving regardless of radio on or off. 2.2.
Post #204811 23rd Jan 2013 10:17pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Usual build quality then Whistle
Post #204834 24th Jan 2013 12:12am
SGoggin
In the My12 tech reference manual, it mentions that if the alarm light flashes whilst driving it indicates that the key fob in use has a low battery and this needs to be replaced.
"If the remote handset battery falls below a pre-determined level, the handset will transmit an additional RF signal code to the anti-theft system module. This signal is relayed to the instrument cluster indicator which emits 2 rapid flashes every 0.5 seconds to inform the driver that the remote handset battery needs replacing."
Post #204844 24th Jan 2013 3:49am
borderterrier
If mine flashed with that frequency, 2 rapid flashes every 0.5 seconds, I would be happy as clearly its meant to do it. Mine is more like a loose connection and comes on when it feels like it!
Steve
Post #204849 24th Jan 2013 7:40am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
This is completely off the wall and really just me thinking out loud, but as far as I was aware the only change on the later sytems was the addition of the battery backed sounder as standard.
I'm assuming that with this added there is some sort of battery management for the sounder, to keep the state of the charge of its battery good. Maybe this intermittent flash on the dash is some sort of 'start charge / finish charge' indication, or the dash module periodically polling the BBS for its current state.
I suppose it would be good to know if anyone that's added the BBS retrospecively has seen the same thing.
Just a thought.
Pete
Post #204910 24th Jan 2013 11:18am
Just a thought.
Pete
The BBUS is 'charged' by means of the permanent 12V supply and any management is entirely self-contained. It is unlikely that the presence or absence of a BBUS will have any effect whatsoever on the behaviour of the LED.
Post #204969 24th Jan 2013 2:22pm
XS Pete
OK Fair enough. I guess there must be some sort of battery management somewhere for the BBS pack, otherwise if (when) a cell eventually dies in the BBS, if there was simply a hardwired connection between the two positives, the main vehicle battery could become discharged by the dysfunctional BBS battery, if you see what I mean.
'tis a mystery
Pete
Post #204977 24th Jan 2013 3:23pm
Page 1 of 3 123>
