Home > Puma (Tdci) > Air Con upgrade?
Page 3 of 3 <123
BruceT
South Africa
Thanks Jason but is this correct:
MILITARY LAND ROVER WOLF TUM RAD-HAZ RADIATION HAZARD INSULATION PROTECTION KIT "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #204329 22nd Jan 2013 1:43pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Yes, it is however cheaper if you call them up and buy two or three I offered £10 each IIRC and then there was the shipping on top so they worked out around £15.
The kits take a little bit of work to sort out, but are well worth the effort, they are basically 6mm closed cell foam covered with canvas, you cut the canvas off them and I also cut squares out where the eyelets had been inserted a square of material and then used the foil tape to repair.
I used two layers on the roof and the floor and as I say used 2.5 kits with some left over which I will use for other bits.
Jason.
Post #204337 22nd Jan 2013 1:53pm
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
Well, I ran my little 'experiment' today. Taking into account the 'instrument' Wink I used is just a $5 clip on digital vent thermometer from ebay, so it won't be the most accurate I know, but to give an idea of extreme difference in air-conditioning temperature output I think its enough for the purpose.
My vehicle is a MY12 90 Puma with the standard rubber floor and seatbox mats, no other insulation (yet). the car has all windows tinted, except front of course. I clipped the 'instrument' onto the fixed vent on the drivers side of the clock. The air-conditioning was switched on with no fan assistance added, set on recirculate and the vent dial was set to just the upper vents only for this 'experiment'.
During the test the ambient air temp was between 23 and 24.5 deg c. When I started at 10.55am, the temp in the car was 21.9c. I then drove along the highway (100 kph area) where the aircon temp dropped to the lowest of 0.4c at 11.13am, from here it began to slowly rise to 8.3c at 11.25am when I reached by destination 33 kms from where I started.
At 12.56pm I resumed my test the aircon temp showing 8.1c after driving a short time. Once again I was travelling at 100 kph. At 1.14pm the aircon reached its lowest temp of 0.7c.
I travelled about 60 kms this leg and at 1.34pm the aircon temp had risen to 9.2c. I then drove around a 50 kph area until 1.39pm and the temp had risen to 11.1c. I returned to driving at 100 kph and travelled home (about 26 kms) and upon arriving at 2.06pm the aircon temp had risen to 14.1c.
Once parked in the garage the overflow/dripping from the aircon unit didn't start for about 10 to 15 minutes.
While driving you can definitely feel the heat coming from the seatbox/tunnel area after a while, I think I can actually feel the heat permeating up through the seat cushion ..... No doubt this does add to the cabin temperature but I would have thought an efficient air-conditioning system would overcome this. Bearing in mind the outside temp was only 23 to 24.5c as well Shocked in my recent vehicles in this type of temperature I would actually be warming the aircon temp up a little.
I also noted that the aircon compressor in the engine bay, the pipe that comes from the back of it there is a blue cap on a fill/empty valve. Between here and the silver insulation when the aircon is on for a short time this pipe is cold to touch, at the end of my 'experiment' today this portion of pipe was hot to touch, the other side of the insulation just prior to entering the bulkhead the pipe was cold but not ICE cold.
Well no doubt all of this means jack...t but I said I would post my results on AULRO and thought you guys might be interested, maybe not.
I WILL in the near future insulate the vehicle and hope for better results from this meagre aircon.
Sorry for the long winded post Smile
Mick
Post #204598 23rd Jan 2013 9:18am
BruceT
South Africa
Interesting thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #204615 23rd Jan 2013 10:19am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thanks for the info. So to make a long story short, the solution is insulation! Or a D4.......
Post #204638 23rd Jan 2013 11:36am
mk1collector
That's what I've been saying for the last couple of pages Mr. Green
Post #204669 23rd Jan 2013 12:27pm
BruceT
South Africa
Yes but we didnt believe you..... Rolling with laughter
Just joking. Smile "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #204672 23rd Jan 2013 12:28pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Here today overcast and "cool" at 25°C ... so no blazing sun and had to turn airco down from highest setting!
Guess time to source some insulation/sound proofing and solar film for the windows.
Post #204845 24th Jan 2013 3:22am
pannawonica
Australia
I think you're all on the money with improvement ideas, but at the end of the day when the sun is hot its 50C and you can fry an egg on the road bigger/powerful aircon would fit the bill. Thumbs Up
Post #204847 24th Jan 2013 4:03am
Page 3 of 3 <123
