![]() | Home > Td5 > Low range - lack of response? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
When you select low range, a switch in the t/box changes the characteristics of the throttle pedal.
Not much happens for about 80% of the travel then the last 20% will rev the engine. Think it was designed for folk who can't 'lock' their ankles whilst bouncing around rough terrain and thus get kangarooing There's a plug on the t/box you can unplug to stop it....I have on mine; much nicer. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
Cheers, yea that about sums it up, 80% nothing then life!
Will have a look. Is this plug easy identifiable from underneath the car ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
The switch is in the casting on the top of the t/box where the hi-low lever goes into:
![]() Image from Ashcrofts; see the red plastic plug? it goes in there, and has a few inches of cable and a moulded (grey I think) plug on it. which plugs into the vehicle harness. If you do unplug it, cover both ends in gaffer tape, just to keep the crud out of the pins. |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 ![]() ![]() |
Hi
The red plug is actually the breather, I will try to post up a photo of the high/low switch tomorrow, Dave Dave |
D'OH!!!! You're right (of course) Dave... whoops!
![]() ![]() Well, it's in a similar area of the box, more down on the main casting IIRC, with the flylead and plug. ![]() |
this one :
![]() Dave Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks Dave, that gives me a good idea.
Cheers for your assistance & everyone else. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
