Home > Technical > Winscreen Removal & reffiting
Dieselhead
Hi,
A mate has a 90 with a very poorly winscreen rubber which needs replacing
Now I once watched an auto glass man change my winscreen on my old 300tdi, it was all done in 20mins & he told me that these are very easy to do.
He just pushed out the sreen, swapped the glass over & reused my old rubber. He used a bit of string etc.
Now is there any where with a correct write up with pics on how to do this your self???
If your screen is heated, is it easy to disconnect the wiring?
Many Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #203130 18th Jan 2013 7:58pm
MartinK
I've wondered about this too.
Sealey do a windscreen kit for about £40:
There's a few instructions on the web:
Quote:
Inspect the gasket's condition; if it isn't dry and/or hardened, you could use it again. Otherwise, cut it away with a carpet knife or similar blade. Plunge the blade into the rubber gasket, making sure you don't hit the glass, and carefully cut along the circumference of the glass. You can now remove the glass by pushing it out from inside the car with your foot and a large stick; have someone catch the glass from outside. After cleaning away any rust and debris from the frame, apply sealant to the inner edge of the gasket and attach the gasket onto the new glass. If you're using a new gasket, let it sit in the sun for up to an hour to soften; if the weather outside is cold, let it sit inside in a warm room and just make sure it is pliable. Apply petroleum jelly to the gasket's outer edge and run a nylon rope around that edge, making the rope ends meet at the bottom. Have your assistant lower the glass onto the frame and press on the gasket while you grab the rope ends from inside the car and pull on them, pulling the gasket's inner lip inside the car.
Read more: DIY: Windshield Replacement | eHow.com http://www.ehow.com/way_5332866_diy-windsh...z2IMQwcSto
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #203146 18th Jan 2013 8:26pm
bob neville
Hi Chris
I have the same problem on the TD5.
Had Nationwide windscreens out to fix a chip in the Boxster's screen two weeks ago and asked the fitter the very same question.
His advice was that if the seal is shot the best thing to do was cut the glass free by removing the outer rubber, he said most breaks on Defender screens were on removal.
Fitting is the old string trick plus lubrication.
He said the cost to remove the screen, new seal and fit (plus seal the screen) was £50, and if they break the glass they have to replace it.
Heater connections are a couple of spade terminals just visible above the dash.
2013 Defender 90 CSW - sold
Post #203150 18th Jan 2013 8:31pm
Shame you guys aren't local to me, I'd do it for free. I worked in the windscreen trade for years n years.
Post #203153 18th Jan 2013 8:39pm
Dieselhead
Many Thanks for the info guys
We may give it a go when the weather warms up Laughing Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #203154 18th Jan 2013 8:40pm
Dieselhead
Thanks for the offer
Best tips on doing a defender screen then please Whistle Bow down Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #203155 18th Jan 2013 8:41pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Can he find two chips however toy less than 10cm apart to justify calling the man out under an insurance claim?
Post #203156 18th Jan 2013 8:43pm
Retroanaconda
Just crack the screen with a hammer, then you've got your insurance claim.
Post #203302 19th Jan 2013 12:40pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Cost me £75 excess when I had my heated d3 screen replaced , it was cracked by a stone thrown up by a lorry though.
I think for £50 I know what id be doing (me not being too mechanically minded)
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #203326 19th Jan 2013 2:17pm
When you're ready do it, pm me your number and I'll call you, it's easier to explain on phone than to put down on text Thumbs Up
Post #203329 19th Jan 2013 2:29pm
Dieselhead
Will do
Thanks Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #203369 19th Jan 2013 5:01pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Had my windscreen rubber replaced. Evidently as the Defender screen is flat there's more chance of breaking it rather than a curved screen which is intrinsically more rigid. I took mine to the local (non franchise) car glass place who charged me a small fee to swap the rubber!
Andy.
Post #203373 19th Jan 2013 5:05pm
After toying with the idea of doing it myself, I had a local independent fit my heated screen and was glad I did.
The old one had one big and several small chips, as it was being removed it cracked completely. It is apparently very difficult to remove a Defender screen without breaking it if it has any defects if you want to reuse the rubber.
As far as the rubber is concerned, early ones (mine is '07, not sure when the cut-off date is) were more flexible and had a better water seal than the later ones (hence the water ingress issues on later vehicles). If you have an early seal in good condition, it will generally seal better than a brand new seal.
I paid £60+vat for the job; money well spent in terms of saved hassle and risks avoided imho.
Post #203392 19th Jan 2013 5:54pm
