![]() | Home > Td5 > Starter Motor Removal |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
You need a flexi head extension about 5" long... usually easier from the top.
If you can bump start it, bring it over to the workshop and can do it in the warm. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
Ahh that little devil!
The way I did it was. 15mm socket on a small extension, put this on from the inside the engine bay looking down (its a tight fit but doable) and then with the socket and extension on, dive underneath and then put the ratchet on trying not to dislodge the socket/extension. Its a difficult one to do, even more so in the cold! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Cheers Ian, It's parked so awkwardly I can't get it moved enough to bump it. I'll battle on tomorrow. I can't find my 1/4 or 3/8 sockets ![]() |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Very difficult, if not impossible, to get at it with a 1/2" drive set, you really need a 3/8" set with a nice long extension and i personally do it all from underneath. The first time i did one was in the snow on a friends disco in the pub car park, it wasnt much fun!!
Pete. |
I did mine with a 1/2" drive last year, IIRC I put a 6" extension on the socket, then a long one and another one and the ratchet ended up near the radiator! It did make I cuss quite a bit but doable
I've got to locate the darn nut first. It seems that every pipe and wire that could be run over the starter has been just to make it harder. Does anyone have a TD5 engine out of the car that could be photographed so I can try to visualise it?
