![]() | Home > Maintenance & Modifications > Staun Beadlocking Bags |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
so do you have to have the staun alloys too? or could they be fitted to Boost's? 110 Tdci Double Cab
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
They can be fitted to any wheel
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
you should get down to 8 psi to10 with them tire any way i run in the sand at 12 psi RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Hi Ray, the idea of the bags is to lock both beads to the rims and also if you get a puncture the bag stops the sidewalls from getting destroyed if you need to drive on it flat for a while
