Home > Technical > Diff lock not engaging |
Hi Keith. It sounds as if part of the linkage has seized up a tad, in most cases it is the "C-Link" that causes the problem. I wrote a "how to" for the discovery, but the linkages are pretty much identical and which can be found here; http://forum.landrovernet.com/content.php/...-Diff-Lock Apologies for the link away from this excellent forum. |
18th Jan 2013 12:01pm |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
Thanks for that, unfortunately I cannot gain access to the forum (even tried to register but not working). Any chance you could (please) copy the topic if possible. Thanks in advance Keith Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
18th Jan 2013 12:16pm |
Let's see shall we... |
18th Jan 2013 12:37pm |
Here you go, a few minor edits required. Obviously this was done for a Disco, but like I said the linkages are the same. Good luck.
How to... Discovery TDI Stuck Diff Lock ...Working again... :yay: Well it didn't when I bought it but it does now and here's what I did and what was preventing it from engaging. The problem with anything that is not used is that it gets stiff and when you need it most it doesn't work, this is the fate of 75% of all Discoveries ever sold I would think. The most common example of this is that the difflock will not engage. Having read a lot of other peoples experiences 95% of the time it is NOT the transfer box that is broken it is that linkages that are not functioning as they should. Some find that the main transfer lever just refuses to budge and some that it moves but won't engage difflock. In my experience a good clean and lots of lithium grease solves this problem. Set yourself a good day aside to do the job and be methodical, dare I say it, leave Land Rover Special Tool No.1 in the garage...! This job is about finesse...! Diff lock not engaging properly or at all, sometimes intermittent disengaging when clutch was depressed. Unlike some of the diff lock stuck problems I read on various forums I was relieved that the actual diff lock lever mechanism did move, if stiffly and with some considerable force. I read other peoples words of wisdom; Wise words 1; http://www.landyzone.co.uk/lz/f8/freeing-u...59819.html Wise words 2; http://www.landroversonly.com/forums/f9/ho...uck-43161/ Wise words 3; http://www.discovery2.co.uk/diff_lock.html (not a diff lock stuck thread, but some very good pictures of how to get to the transfer box levers from inside the cab) Now I thought I would add my experience to the hefty weight of theirs. The Plan: Clean and grease lever mechanism and establish why diff lock is not engaging properly, if possible fix the problem. How long: The wise words of those that have gone before recomend at least a day to get this job done comfortably. I would agree, especially if you take the time to clean and grease every part of the lever mechanism like I did. Tools: Quite a lot but nothing too special; screwdriver (pozi-drive and flat), needle nose pliers, drill and selection of metal drill bits, pop rivets, pop rivet gun, spanner (7mm), 1/4 socket set and sockets (room is tight hence the 1/4"), hammer, small punch, lithium grease, small wire brush and rags. Directions: As with the above words of wisdom;
Should look like this - (Borrowed from LR4x4 Forums - http://forums.lr4x4.com/index.php?showtopic=6719) Now the fun begins... Click image to enlarge
I am not a fan of the grab the handle and beast it back and forth left and right approach, much preferring to dismantle, clean and rebuild... So, NB: Should the difflock engage and the dash light remain off this is your chance to sort that problem out as well. Could be a faulty switch, bad wiring or badly adjusted switch. Re-assembly is the reverse of of dis-assembly and all that. I am glad to say that the Discovery is now fully functional in the difflock area, now I just have to re-bush it as they are beyond goosed... :rolleyes: I hope this helps others solve this all to common problem with second hand Discoveries... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
18th Jan 2013 12:48pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8101 |
a good article.
if its desperate you can engage it by removing the C linkage and using a spanner on the spigot. or apply force to the side of the C linkage. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
18th Jan 2013 12:51pm |
IIRC the nut is a 13mm to get the linkage off and the spigot is a 10mm spanner. |
18th Jan 2013 12:53pm |
