Home > Maintenance & Modifications > Auxiliary battery location ideas
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Just wondered what people have done to fit secondary batteries. I've seen them fitted into the battery box, but was wondering how feasible this is, as they look very tight. I would be fitting a smaller auxiliary battery, not for winching or anything dramatic, rather for short term use of electrical items such as lamps or (small) compressor.
Post #202754 17th Jan 2013 10:02pm
excossack
I fitted a 2nd battery into the battery box under the seat, it is a tight fit but doable depending on the size of battery. I use my 2nd one for additional 12v aux sockets, charging torches, radios for rallies, cool box etc. The winch is off the main battery. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #202758 17th Jan 2013 10:07pm
appaloosadude
That sounds like what I have in mind. Do you have any pics or battery specs?
Post #202761 17th Jan 2013 10:09pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Two batteries fit ok with room to spare for cabling, extra fuse block and cut off switches. Rather than add to stock battery, I went for two identical batteries from same batch and wired in parallel. Simple, but very effective.
Steve
Post #202763 17th Jan 2013 10:10pm
excossack
Might be able to get some pics tomorrow if its not snowing/raining or bitterly cold I shall see what I can do. 1999 Defender TD5 110
Regards
John M0VAZ
Post #202764 17th Jan 2013 10:11pm
JWL
I've just changed my auxiliary battery and went from my old caravan battery(75ah) to a 110ah jobbie. This is fitted in the seat box along with the standard vehicle battery, just be aware the shape of the bottom of the seat box can hamper some sizes, the second battery sits on a raised portion and I sourced one off t'internet with a height of 190mm which gives it some clearance under the lid panel even if it is all the way to the back of the seat box. Still got room for the charging relay, jump leads and a few other things I haven't got round to putting on yet Rolling Eyes
Post #202782 17th Jan 2013 10:53pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Step-by-step directions from LRM/Mobile Centre:
http://www.mobilecentre.co.uk/images/Data_...ue_Sea.pdf 2013 Defender 110 XS DCPU
2016 Ford Mustang 5.0 V8
Post #202792 17th Jan 2013 11:17pm
leeds
A couple of photos for you
Brendan
Post #202798 17th Jan 2013 11:46pm
I made one in my old 90 (although my current 110 has an ex Wolf unit.
The wolf one fits optimas in OK, but the top clamp won't fit them (as the top of the batteries is too wide) so made my own one up with a piece of flat bar.
For the 90, I just got a flat piece of steel (think it may have been chequer plate) fairly beefy, 3 or 4mm thick. and welded on a piece of box along one edge. box was the same width as the recess is in the battery box.. can't remember what it is, about 30 or 40mm I think.
Bolted this down to the bottom of the battery box, placed the batteries in where I wanted them, marked for the upright studs either end and one in the middle.
Removed the plate, drilled the holes and welded a nut under each hole. Then refitted and used some studding (6mm I think, or 8mm, depends on what we had at work), cut the studding to length (height of the battery plus 1/2" or so) and welded a nut to the end of each one, to make a long bolt. cut a piece of flat bar to cover the batteries (about 30mm x 5mm) and drilled it to match the holes in the lower plate. then bolted the lot together.
Unfortunately not got any piccies of this setup.
Pics of the proper wolf mount in my 110:
The holes and studs on this wolf bracket lined up perfectly with holes already in my Td5 seatbox :up
Withe the proper "wolf" clamp:
Home made clamp:
Batts in sit:
As per the factory (military spec):
Post #202803 18th Jan 2013 6:53am
Naks
It's a tight fit in the Puma but it can be done:
Post #202808 18th Jan 2013 7:22am
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
Brendan/Naks
Just looking at your photos, did you still use the original battery connector with the Mega fuse in?
Post #202832 18th Jan 2013 9:41am
Naks
deep down wrote:
Brendan/Naks
I left it at the auto electrician for the installation, so I cannot answer --
Post #202837 18th Jan 2013 9:47am
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Twin Odyssey installation
It is tight but with a D44 tray you can get two serious batteries and fuses, relays etc in the space
Post #203104 18th Jan 2013 6:41pm
leeds
deep down wrote:
Brendan/Naks
If you look at the top let hand corner of the photo you can see the original red cap with the mega fuse on side of the battery. Extra slots were cut in the cover for the additional 35mm2 cable.
Brendan
Post #203114 18th Jan 2013 7:14pm
deep down
Finished the installation of the dual battery system.
It is a bit of a squeeze, extra flexible battery cable is the answer.
I went for the Blue Sea Marine auto charge system and extra fuse box and whilst I was at it fitted an Anderson connector.
I already had the Yellow top Optima but has to go for a Red top for the starter so I could use the original positive battery connector, the posts are too far in from the edge on the yellow top. I also had to change the direction of the cable coming off the bottom of the Mega fuse to allow it to fit.
Post #207519 2nd Feb 2013 6:15am
