Home > Puma (Tdci) > Heavy smoke on cold start
Sventheviking
United Kingdom 2008 Defender 90 Puma 2.2 HT Keswick Green
Hi guys. Latest problem with my 2007 Puma at 24k. On cold starting its smoking blue smoke very heavily for about 5-10 seconds then clears. This has been accepted by the main dealer as a fault and after consulting with LR, they failed to find the problem. It's due to go back for another investigation and they want to keep it a week as the problem only manifests itself on initial startup otherwise it starts smoke free has anyone else experienced this problem?
Post #202471 16th Jan 2013 10:05pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
My 2009 has gone in for exactly the same issue this morning. I'll update when I can. Cheers,
Superspoons
Post #202474 16th Jan 2013 10:11pm
Laurie
Heater plug(s)?
Post #202475 16th Jan 2013 10:14pm
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Mine is the same 57 43k and also has a terrible screach from the turbo don't worry about it
Post #202478 16th Jan 2013 10:26pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine smokes like mad if I start it without letting the glowplugs heat up....
I wouldn't worry too much, unless it starts to do it all the time. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #202480 16th Jan 2013 10:44pm
rossy
mine does too in cold weather. So does my father in law's Puma 90. I believe its normal and due to some sensor in the engine calling for extra diesel when the ambient temperature goes below about 5 deg C in order to assist cold starts Thumbs Up
Post #202493 17th Jan 2013 12:14am
Sventheviking
Thanks Guys, I'd be interested what they say to Superspoons, and I'll post what my dealer comes up with next week but its reassuring others have it and it appears to not be something more serious developing.
Post #202599 17th Jan 2013 3:27pm
superspoons
Had a call from the dealer this morning regarding the start-up smoke.
They have found "a loose screw which has shorted a special fuse" which is causing the issue Shocked
Now, I'm pretty handy around a Landy but never have I heard a problem described quite like this Rolling with laughter
A new fuse is on order and should be fitted tomorrow, I'll try and find out exactly what they mean when I pick it. Oh, and it passed the MOT Thumbs Up Cheers,
Superspoons
Post #202604 17th Jan 2013 3:58pm
superspoons
Utterly Censored off
Just been charged £200 for a £7.50 fuse which has been replaced to 'cure' the blue smoke on cold startup.
"Warranty does not cover fuses"
....it may not but the fuse blew due to a short in the system caused by a loose screw. I saw the technicians note.
Argued the toss, got nowhere. No real surprise.
I was due to sit down with the salesman who sold me it back in April to discus a new 2.2 ... Absolutely no chance now. Not there, anyway. If I do change I'll buy private and take my chances - the warranty as I see it is not worth the paper it's typed on. Cheers,
Superspoons
Post #202985 18th Jan 2013 3:22pm
mk1collector
Time for a letter to LR head office! I wouldn't be standing for that
Post #203005 18th Jan 2013 4:05pm
puma2010
England 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Hi mine is the same, I informed LR who sent a techy, it turned out to be the enrichment, it only does it in the cold weather, nothing to worry about mate.
Post #203852 21st Jan 2013 2:52pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
mine was the same i put a thread on here somewhere, cure was an injector learn by dealer, all good now Thumbs Up
Post #203950 21st Jan 2013 5:58pm
