Home > Maintenance & Modifications > Wheel carrier spacers.
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
I'm just ordering 265's and I understand the extra width on the spare will foul the movement of the rear wiper. I know people use spacers to solve this problem. Are these homemade or commercially available?
Post #201659 14th Jan 2013 9:01am
geobloke
Re: Wheel carrier spacers.
I have the expedition equipment carrier fitted and it has no problem with fitting 265/75/16 tyres on both boost and modular rims. The only thing that you have to do is adjust the spacer nuts by about 15mm. Incidentally the standard defender rear door carrier fits 265s absolutely find too.
Post #201660 14th Jan 2013 9:05am
SteveG
2005 Defender 90 Td5 CSW Belize Green
I just use 3 LR steel nuts as spacers and this works fine.
Steve
Post #201661 14th Jan 2013 9:06am
SteveG
It depends on wheel some of the later alloys like blindo, dakar have a large positive offset and so can cause issues, even with 265's.
Steve
Post #201662 14th Jan 2013 9:09am
Thud
My wheels will be Boosts.
Post #201663 14th Jan 2013 9:14am
RED-DOT
You will smash your tail light lense if 265's are on a taildoor standard setup. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #201677 14th Jan 2013 10:59am
Thud
*Rushes out to car and opens rear door* It will be close. Am I missing the obvious solution? Do I need a different carrier?
Post #201690 14th Jan 2013 12:16pm
landy andy
265 BFG on boost wheel, fitted to standard wheel carrier did not break my rear lights but did stop my rear wiper working, enough to blow the fuse on the journey home after collecting it Big Cry
Andy
Post #201802 14th Jan 2013 6:57pm
Thud
So should I buy a deeper carrier? Swing mount carrier? There are plenty of people running 265's what are they all doing?
Post #201804 14th Jan 2013 6:59pm
landy andy
I use a swing away carrier. An alloy with a 265 BFG weighs a far bit, and that's not good long term if you off road. If you stay on the black stuff don't think it will be so much of an issue. Before the swing carrier I used spacers, think they were karting wheel ones that I had knocking about.
Andy
Post #201811 14th Jan 2013 7:03pm
dhopable
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Ive got a 265 kumho on a boost on the door of my 90.
Didnt smash the rear light - no where near! Thumbs Up
But dd hit the windscreen wiper Evil or Very Mad
Went to the farm workshop, put two stainless washers on each bolt, job done.
Wiper doesn't hit, light isnt smashed. Thumbs Up
Ill stick some in an envelope if you like we got a million of them! Whistle Cheers
Doug Thumbs Up
Post #202242 15th Jan 2013 9:36pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
You should have spacer nuts as standard on your rear wheel carrier. Just adjust them out so the new tyre misses the wash wiper.
I ran the original rear wheel carrier for a short while with a 265 BFG before installing a separate wheel carrier. 2007 TD5 90 Hard Top
Post #202261 15th Jan 2013 11:09pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I agree with above.
I have 265s on Boosts.
I adjusted the standard carrier to provide clearance for wiper...( absolute minimum)
The wiper is fine.
With a new tyre on the wheel it just touches the back panel with the door pushed right back. No damage, no lights broken and no cost....well except for additional chain and lock to secure wheel!
I do intend to shorten my door stay....as realise with wear there is a risk of marking the back panel.
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #202263 15th Jan 2013 11:22pm
Thud
Thanks for the replies and advice. It seems all should be okay with clearance with either adjusting the OEM carrier or adding a spacer. Cheers folks.
Post #202285 16th Jan 2013 8:32am
