Home > For Sale & Wanted > For Sale rover drive DS |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
Rover Driver for sale model DS The DS model Roamerdrive is the latest upgraded version for Land Rover Defenders The upgrade includes a new shorter casting more open front-end architecture that enables the oil shared with the transfer case to be circulated
in Good order all parts included £ 650 removed from TD5 email blackadd@clara.co.uk have pic but can work out to up land them |
15th Jan 2013 9:44am |
about 700 miles pox trip to Cornwall and back Dorset
15th Jan 2013 11:56am |
Bargain that. If I hadn't put a Disco box in I would buy it.
15th Jan 2013 11:57am |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 616 |
OK this sounds a really good bargain, but why would you loose the best part of £800 on a 700 mile journey??? Did you not like the Rover/Roamer drive, are you selling the truck? |
15th Jan 2013 12:16pm |
can be fitted with out having to remove the transfer box the only thing to be removed from transfer box is the PTO drive cover and drive gear, new bearing
Fill INSTALLING manual inclosed |
No not selling the landrover you pay moor if you wont
15th Jan 2013 12:23pm |
Sorry, the thing I was trying to ascertain was, why are you selling the overdrive with so little use and at such a substantial financial loss?
15th Jan 2013 12:34pm |
to hard to no wot price used part i am not looking to make mercer bucks all also the mane reason for fitting it towing and fuel consumption as i will not be towing the boat that far from now on
15th Jan 2013 12:50pm |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 |
I will consider this might be cheaper to just change the tbox £ 450
15th Jan 2013 3:03pm |
The advantage of the overdrive is that it lowers the revs by more than the transfer box, without making 1st gear more difficult for towing etc.
15th Jan 2013 6:03pm |
jellyo Member Since: 30 Jun 2014 Location: england Posts: 6 |
hi guys so did you sell it if not I'm interested if its ok thanks jd
30th Jun 2014 10:27pm |
