![]() | Home > Puma (Tdci) > brake issues HELP!!!! |
skiboy Member Since: 14 May 2012 Location: milton keynes Posts: 21 ![]() ![]() ![]() |
anyone ?
sorry for the swear word, didn't even know i had put that in ? |
bwanashamba Member Since: 03 Jan 2012 Location: tanzania Posts: 14 ![]() ![]() |
Check the brake booster,your brake fluid resovoir is attached to it, you cant miss it. The booster has a large rubber grommit attaching a plastic tube to the body of the booster, check this grommit is not leaking air by having someone pump the brake peddle while you listen.
Hope you come right ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8168 ![]() ![]() ![]() |
its fine.
where you describe the brake pedal going down after starting the engine etc, it should do that. stop worrying. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
