![]() | Home > Puma (Tdci) > performance, Cruise Control & Steering wheel |
Factory for which vehicle as cruise has never been offered on the Defender by the factory ?
DAM Member Since: 06 Jan 2013 Location: Kent Posts: 14 ![]() ![]() ![]() |
Here's the link
http://www.terrafirma4x4.com/mobile/search...se+control There are two options regards David |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Where do these units connect to monitor the vehicle speed..? I guess it needs another connection..? Cheers Simon |
Quite right, forgot that bit
![]() Single connection to dash clocks loom |
Details of the TERRAFIRMA CRUISE CONTROL KITS
The electronic cruise control Kits are available for 2002-2007 Defender Td5 and the newest 2007 on Defender Td4. Functions are controlled by two buttons. The speed is adjusted using the SET button. When this button is held down, the Defender accelerates; when it is released, the Defender maintains the current speed. The second button, RESET/RESUME has two functions. If cruise control is active, pressing RESET/RESUME deactivates it. When it is pressed again, the most recently stored speed is recalled, and the Defender gradually accelerates automatically until this speed is reached. Cruise control is also deactivated when the brakes or clutch are used. Cruise control can generally be used at speeds of 45 km/h and above. TFCCK Terrafirma cruise control kit - Defender Td5 2002-2007 TFCCK07 Terrafirma cruise control kit - Defender Td4 2007- on TFCCKTD5 Terrafirma cruise control kit - Defender TD5 1998 to 2007 [/img] regards David |
http://www.defender2.net/forum/topic2266.h...p;start=60
More info here - there was a solution from Sonic3d/Allisport... |
Any details on the boss, I'm looking at the Momo Tuner wheel, will it work with that model..? Cheers Simon |
series1 Member Since: 18 Jan 2013 Location: Finland Posts: 1 ![]() |
Go Beyond, how did you locate the right wire from the dash loom? I assume this is for the speed or rpm signal. I am about to install a Mobile Centre cruise control to a 2011 90 and the rest seems pretty straight forward. Thanks for any tips! Cheers from northern Finland! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Gary is right the mountney boss is horrid and fits really bad, i have one of the Alive boss's on my 90 and it really is the bomb ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Hi Series1, the instructions give the PIN number of the plug that goes into the back of the instrument pod.
Unplug it and its quite straight forward, although mine is probably easier as I have the dash out ![]() |
First, agree with the common rail boxes, keep away!!!! Your engine Will be happy Second, the right dia for the Defender steering Wheel mod is 360mm or, better, 380mm but this diameters are not easy to look for..... The 360mm ![]() Click image to enlarge And the (actual) 380mm ![]() Click image to enlarge both Nardi and the boss is Nardi also Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License Last edited by dgardel on 20th Jan 2013 7:14pm. Edited 1 time in total |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
My cruise kit was from Sonic3d/Allisport , a few years ago now ,,
Was then not a plug and play, but easy enough to wire, most into the throttle switch,, The speed input was a small problem, as the pulse from behind the dash was not strong enough !! so when back to the speed sensor on the gearbox,, easy enough ![]() Cruise must be in the top 3 of mods fitted, and fitted in a way, that it will be coming off and put on the next 110 Rather than drilling for a stalk switch, silver switch panel on the center panel ![]() Click image to enlarge 350mm Momo Nero for me ![]() ![]() Click image to enlarge Recon my remap has lost maybe 10% fuel consumption !! but then i may drive it a tad harder now ! ![]() struggle to better 22mpg, probably down to 265 tyres, roof rack and RAI etc ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
