Home > Maintenance & Modifications > wiring diagram for rear wiper switch as aux switch
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
i want to use a rear wiper switch YUG000350LNF to power 2 rear work lights as i cant bring myself to spend £50 on a front fog switch, im guessing it can be done but has anyone got a diagram on which pins wire to what ?
thankyou kind gentle persons Very Happy LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #199733 7th Jan 2013 5:43pm
Looking at the Rave diagram, Pin 1 is Earth, pin 4 is the live (via whatever you're trying to switch)
The wiper motor is "live" via the ignition, and switched to earth through the dash switch. If you were to wire it the other way round just as a normal switch, you'll find that the warning light on it won't work properly.
It's not a problem though... take the power feed for your spotlight relay (fused, naturally), through the coil of the relay, then to the switch (pin 4) then to earth (pin 1) and it should work just as the rear wiper did.
Post #199744 7th Jan 2013 6:25pm
mattlab
thanks jim, much appreciated.
matt. Thumbs Up Thumbs Up LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #199777 7th Jan 2013 7:52pm
