![]() | Home > My Defender > The FCX Defender 130 build thread |
120mm 'square' available left and right of the outer brackets SGH
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I've been busy over the holidays ....
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The twin battery kit was supplied by Tim at Mobile Centre and at the risk of being accused of 'bigging up' fellow sponsors, it really is a quality bit of kit with a 'Beautiful' stainless steel battery tray that once it's fitted, you can't see ![]() Mobile Centre supply the parts to mount the accessory fuse board in the battery compartment but I've opted to place it under the drivers seat where there is more room - hence the 70mm cable .... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks Steve, 'stripping out' was the easy bit
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20634 ![]() ![]() |
Hope you've labelled everything.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Although it looks complicated infact there isn't a lot to the Puma dash, removal took 30mins tops and that included removing the (stubborn) steering wheel !
So far I've fitted the twin battery set up, intelligent charger, aux fuse board, kill switch for winch (in an FCX battery kill box of course) and Cruise control. I've run cables to the tailgate area for the additional reversing lights, rear camera, fridge power and LED hazard lights. I've also run power and control cables to the rear seating area for two amps and powered sub. Control cables are routed to the cubby switch box location and up to the roof for the new FCX roof console. I'm not going to divulge 'Security' but there's a lot of it ![]() Still plenty to do but the leather is coming along nicely ![]() |
Very good. if you going for two Amps will be powerful too.
![]() P.s. Did you use Proflex cabling for your Amps? TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
I've used www.theloudest.com stuff, this amp for the rear 6 x 9's:
http://www.theloudest.co.uk/index.php?id=v...uct_id=147 and this amp for the front 4": http://www.theloudest.co.uk/index.php?id=v...uct_id=146 the dash tweeters will be run from the head unit. I used their wiring kits: http://www.theloudest.co.uk/index.php?sect...duct_id=77 The 130 has a 150 amp alternator which is a bonus ![]() PS - Just for you Steve I'm using the Kenwood powered sub ..... ![]() |
Excellent.
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Fitted an FCX Expedition Lokbox to the FCX 130 this weekend ...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
that must have been a bum clenching first cut
![]() how many times truthfully did you measure that? ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Only the once, I have done a few now
![]() 50mm in from the two edges, cone cut holes in the corners, check there's nothing underneath and crack on ! ![]() |
Would it not have been easier to measure up then remove the plate out of the footwell cut and then re-fit? Easier to get at then and no risk of anything getting cut underneath. Or am I missing something?
You could have done Steve but it wouldn't have been easier, you would have to break the factory mastic seal on the plate and then redo it afterwards and also have the hassle of holding the plate whilst cutting.
This was a five minute job from start to finish, really no need to remove the plate and there is nothing underneath to cut. |
