Home > Puma (Tdci) > mantec snorkel |
I mounted one of these RAIs with rivnuts. Suppose you could try using nuts behind the panel but you only need to insert 2 rivnuts - make your own tool?
http://www.defender2.net/forum/topic8631.html Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Jan 2013 8:44pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Ok will try it.Just goes against the grain drilling into the wing and not knowing if homemade tool will work as i havent got any spare rivnuts
4th Jan 2013 8:56pm |
No sweat - rivnuts are cheap off eBay and if you cock up they are easy to drill out and try again without any further damage - believe me, I know
Just remember - "measure twice, drill once" p.s. Many on here would also make the seal airtight with Sikaflex. I used butyl tape but I'm... "unusual" Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 4th Jan 2013 9:13pm. Edited 1 time in total |
4th Jan 2013 9:09pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Pm your address I'll sendup some if required
Are they M6 or M8? |
You see - no problem Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Jan 2013 9:13pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1381 |
Tip - put masking tape along the seam between the inner and outer wings when drilling the holes in the windscreen surround, as bits of swarf can get in the gap, and can be near impossible to get out again. Euro-Leafing to infinity and beyond.....
4th Jan 2013 9:46pm |
How thIck is the ally window pillar anyway ?
4th Jan 2013 9:55pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Better instructions here https://www.defender2.net/gallery/thumbnails.php?album=26
4th Jan 2013 11:25pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Thick enough to take the self tappers that hold the bracket but do remove the interior screen trim [2 x self tapping screws] and pull the wiring that runs up under the trim out of the way before you drill the holes for the RAI support. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
5th Jan 2013 8:56am |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
I drilled a smaller hole and used a screw thread cutting tool to tap the holes.
6th Jan 2013 7:19pm |
Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20 |
Is there not also water drain off hole to block off inside the wing ?
Nearly trashed my 200tdi going through a ford water over the bonnet because it was'nt |
6th Jan 2013 8:25pm |
Me too (mine was s/hand without bolts). I also coated the threads with Duralac to prevent bimetallic corrosion and seated the bracket with butyl to make it all watertight @Jensen - I'm no wader but (at least in Pumas) there is a hole at the bottom of the airfilter box and one under the fresh air intake duct... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
6th Jan 2013 8:28pm |
They need blocking then if you fit a snorkel . |
6th Jan 2013 8:53pm |
Agree that's a good idea but if you have access to the rear, then why not fit ordinary bolts and nuts rather than rather ugly self tappers? |
6th Jan 2013 9:09pm |
