![]() | Home > For Sale & Wanted > More bits for sale - no auction this time! |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
Cleaning out the garage and I have found more bits. These are for simple sale, not auction as with the other items.
A second bike carrier. This one attaches to a tow bar, so will be suitable for just about anything, except Land Rovers! Range Rovers would be OK, as would any defender without a spare wheel at the back. �20 ![]() Click image to enlarge Hi Lift Carrier to fit to a spare wheel. Wizard Sec I believe, the bracket fits behind the spare wheel and pokes through the centre, then the high lift mounts to the outer bracket. It could also hold waffle boards �15 ![]() Click image to enlarge A Td5 MAF Sensor � bought from eBay and turns out to be a cheap copy. Kept as a spare as its better than a failed sensor, but not as good as a genuine one. �10 ![]() Click image to enlarge Mobile storage systems wallet for the cubby box. Free ![]() Click image to enlarge Td5 Defender harmonic dampener for transferbox. �3 ![]() Click image to enlarge Warn winch cover for 9.5ti. Needs a clean but all there. �15 ![]() Click image to enlarge Brackets for rear tailgate to drop down � just tailgate side. �3 ![]() Click image to enlarge Tdi Powersteering box seal kit for a 200tdi �3 ![]() Click image to enlarge Genuine jate rings �10 ![]() Click image to enlarge One LR towing eye Free ![]() Click image to enlarge ECU diagnostic port bracket for a Td5 Free ![]() Click image to enlarge Td5 Fuel Filter �3 ![]() Click image to enlarge Wheel bearing washers. Free ![]() Click image to enlarge Transferbox oil seal � Genuine x 2 �3 each ![]() Click image to enlarge Td5 wheel bearing � no box �3 ![]() Click image to enlarge UJ for 300tdi ????? x 2 �3 each ![]() Click image to enlarge Serial to USB adaptor � Used to run a GPs such as a Garmin Etrex through to Multimap on a laptop �2 ![]() Click image to enlarge Numberplate holder to mount on winch bumper. �3 ![]() Click image to enlarge Wheel centre from boost alloys. �3 ![]() Click image to enlarge 2 LR spot lamps, no brackets or bulbs. �5 ![]() Click image to enlarge Warn Winch keeper. �3 ![]() Click image to enlarge Td5 Rocker cover gasket for 2002 engine. �3 ![]() Click image to enlarge Mota Lita Steering wheel boss. �5 ![]() Click image to enlarge Teflon coated swivel for Td5 with ABS. �5 ![]() Click image to enlarge 2 x Land Rover Wheel chocks. �3 ![]() Click image to enlarge 2 x 18� piece of cargo track. �5 ![]() Click image to enlarge 20l diesel jerry can, lockable holder and pouring spout. �25 ![]() Click image to enlarge 1 pair of slip on seat covers. �10 ![]() Click image to enlarge I am open to offers on all of the items, postage can be arranged on the small stuff at buyers cost, collection available. Payment via paypal (as a gift), Bank Transfer, Cash, Cheque. Cheers Ben Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 619 ![]() ![]() ![]() |
I'll have the wheel chocks please - let me know how much to post. Thanks David.
Thor - Fine, The auctions finishes on Monday so we can sort P&P then?
Steve - No problem, do you need them posted or can you collect? David - Postage seem to be quite high, about �10 or so? Still interested? 2002 Defender 110 DC |
An update:
Mobile storage systems wallet for the cubby box. Free Td5 Defender harmonic dampener for transferbox. �3 Warn winch cover for 9.5ti. Needs a clean but all there. �15 Brackets for rear tailgate to drop down � just tailgate side. �3 Tdi Powersteering box seal kit for a 200tdi �3 Genuine jate rings Sold One LR towing eye Free ECU diagnostic port bracket for a Td5 Free Td5 Fuel Filter �3 Wheel bearing washers. Free Transferbox oil seal � Genuine x 2 �3 each Td5 wheel bearing � no box �3 UJ for 300tdi ????? x 2 �3 each Serial to USB adaptor � Used to run a GPs such as a Garmin Etrex through to Multimap on a laptop �2 Numberplate holder to mount on winch bumper. �3 Wheel centre from boost alloys. �3 2 LR spot lamps, no brackets or bulbs. �5 Warn Winch keeper. �3 Td5 Rocker cover gasket for 2002 engine. �3 Mota Lita Steering wheel boss. Sold Teflon coated swivel for Td5 with ABS. �5 2 x Land Rover Wheel chocks. Sold 2 x 18� piece of cargo track. Sold 20l diesel jerry can, lockable holder and pouring spout. �25 1 pair of slip on seat covers. �10 2002 Defender 110 DC |
TTF Member Since: 02 Jan 2012 Location: Wiltshire Posts: 305 ![]() ![]() |
Please can you put the winch cover down to me - assume it will cover the number plate/holder which I have as well?
Hi TTF
The cover has 2 holes which the numberplate holder pokes through. The gen kit has a numberplate holder with 2 zeus clips which make it removable. It that what you have fitted? 2002 Defender 110 DC |
Can't get access to the front end at the moment but assume so, if not I may well buy the plate holder as well!!
CCrikey not only do you hoard LR gear but you get everywhere with it too...
LOL,
Yes, I do get about a bit! TTF, Check your numberplate first, as the one I have isnt the right one. If you want to keep your numberplate on the front you will need to have the holder that has 2 clips to allow you to take the top part with the plate on away from the bottom arms. Mine didn't work hence the plate ended up on the roof rack! 2002 Defender 110 DC |
Ill take the LR spots please if you still have them. Could you give me a price for postage to Huddersfield West Yorkshire please.
Cheers Ray |
Hi Ray, somebody is already interested in them I am afraid. If they do not want them I will give you a shout,
Cheers Ben 2002 Defender 110 DC |
Ok cheers
