Home > Maintenance & Modifications > Nakatanenga Under cubby safe box. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Could anyone please advise me:
Will it fit using the original cubby box fittings to the body or will I need to drill? Does the cubby box then bolt to the lid of the safe again using oringinal hole spacing or will I need to drill. Is the safe pre-drilled? Once the cubby box is sited on the safe does it sit back a bit compared to it's original position? Are the 12v units included or is the box just drilled to accept ones that I will need to buy? Lots of questions but then important things cubby boxes. Cheers. |
4th Jan 2013 1:39pm |
Oh very good and fitting instructions too. Good to have the extra tips. Thanks.
4th Jan 2013 3:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Brian - Do you not ever find that too high / gets in the way of elbow room changing gear? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
4th Jan 2013 6:26pm |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
Would it be a big job put the ecu into this then ?
4th Jan 2013 6:28pm |
You may want to have a look HERE An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
4th Jan 2013 6:32pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Not at all Steve, as it is just the right height for resting your elbow on whilst doing lazy gear changes.
4th Jan 2013 8:07pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Some info on mine here;
John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
5th Jan 2013 3:46pm |
More excellent advice. Just need the safe now.
5th Jan 2013 4:27pm |
