Home > Puma (Tdci) > ZU Rims and BFG wobble -Eureka! |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
New ZU and BFG AT combo wobbling badly at 50-60 mph. Checked all bushes, balanced twice, replaced steering damper. It just got worse. After the second trip to the tyre shop (recommended for being the best) my wife could feel the vibration sitting in the passenger seat!
I took a wheel off to check a hub. Couldn't be bothered to drag my compressor out so used wheel wrench. Once loose I noticed that if I rotated the wheel the nuts came off with my fingers easily at around 4 and 7 o'clock. Hmmm, I thought.... There was about 1-1.5mm of movement as I rotated the wheel so I did all the nuts up finger tight constantly turning the wheel before cranking with the wrench. Repeated this on the rest, having to clean out a bunch of swarf from one wheel that had obviously just been forced on with an air gun. I spoke to ZU who said that they cannot really control the thickness of the powder coat but had to allow a certain tolerance for it. Maybe the coating on mine is very thin? They also said they have had a problem in the past with after market wheel nuts. My 110 is an XS, I assume my nuts are genuine.... (fnaar fnaar) Anyway, the upside is there is now NO wobble. |
11th Dec 2012 6:50pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
A good pointer to anyone else with fresh fitted, coated wheels.
11th Dec 2012 6:56pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
If I can I always fit my own wheels as they always seem to a nut up.
11th Dec 2012 7:38pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
With any coated wheel new or refurbed always ream the central hole and the nut holes make no exception
We then zip them up to hand tight then torque bar to the correct Nm |
11th Dec 2012 8:26pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
i always get the tyre fitters to finish off with a torque wrench - and watch them do it - gives me a warm feeling and double checks that every stud has been tightened properly.
I once sat in a car (passenger) and watched one of the wheels come flying past on the Hammersmith by-pass |
15th Dec 2012 4:20pm |
itayt Member Since: 05 Feb 2012 Location: Herzelia Posts: 13 |
Had exactly the same combo and the same problem.
I Replaced almost everything in the car and the wooble didnt stop. Finaly i noticed that the wheel nuts are about 1-2mm smaller in diameter then the zu holes... I made a bracket and placed it inside the wheel nuts hole and inserted the nuts insite and the wooble stopped. the nusts are just too small for the zu wheels... |
1st Jan 2013 9:16am |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
really, is that standard nuts? |
1st Jan 2013 11:29am |
No. Standart Nuts are for steel wheels, the zu rims are alow and need cones as nuts. the nuts are from britpart |
1st Jan 2013 11:34am |
every day is a school day.
1st Jan 2013 11:39am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
IIRC standard LR nuts for alloy wheels work with Zu wheels - could be wrong though ... John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
2nd Jan 2013 12:31pm |
Allow nuts are shaped like cones so that when they press on the allow they wont make damage. still nuts centers the wheel because the wheel nut hole is shaped like a cone. if you use regular steel nuts on allow wheels you will damage the allow |
2nd Jan 2013 12:38pm |
Yes, that is why I said that the standard LR nuts for ALLOY wheels, such as the ones supplied with Boosts work with Zu wheels. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
2nd Jan 2013 1:19pm |
Do you have the LR part number for the LR nuts ?
6th Jan 2013 12:44pm |
