Home > Puma (Tdci) > Transfer Box Leak
Taff
2012 Defender 90 Puma 2.2 HT Indus Silver
Transfer Box Leak
Went in to dealer for its first annual service. Slight leak from front of Transfer Box. Dealer service department said it is a gearbox out job for this to be changed and TB has to be split form gearbox to change it? Seems like a lot of grief for a TB front seal.
Taff
Post #197708 31st Dec 2012 11:20am
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Hi Taff
You have obviously never removed a LR gearbox Very Happy
Actually, my local dealer just did the seal on my TD5, they had it in overnight and I picked it up next day FOC as the recon box was less than 12 months old that they fitted under warranty.
I would assume that they will probably just remmovethe transfer box from the back of the main box, but remember that means removing propshafts, disconnecting handbrake, possibly remove exhaust, any under body protection, drain the tb, then remove that. Then of course there is the reassemby too. He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #197711 31st Dec 2012 11:32am
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
Re: Transfer Box Leak
Taff
same problem Taff, can you let us know what you are quoted to fix it please.
Post #197972 31st Dec 2012 9:37pm
ericvv
Post #197994 31st Dec 2012 10:23pm
adiep
ericvv wrote:
Should not cost a penny, falls under warranty for a 2012 car.
Ah yes, the OP has a 2012... mine is a 2008 unfortunately !
Post #197998 31st Dec 2012 10:26pm
Taff
This is the first one I have ever owned with a warranty. Have driven ones in Kenya but it did not matter what leaked out of them. Will keep you posted. Getting work done in a week or so.
Post #198013 31st Dec 2012 10:59pm
adiep
cheers Taff.
Post #198019 31st Dec 2012 11:12pm
megatoad
Hi adiep, mine is a 2006 TD5 with extended warranty, do you still have extended warranty? if so try them.
When I bought it 18 months ago from the dealer it came with the warranty and after I complained about finding it hard to engage 3rd and reverse they agreed and changed the box with no quibble.
It was only last October I noticed drops of oil on thedrive and after crawling underneath found the bottom of the transfer case coverred in EP90.
Fortunatly I had just extended the warranty again (�460 a year) which I was was sceptical about at the time but in th case if the transfer oil seal I think paid for it self.
So if you have any warranty left try the dealer. They will warn you that they charge you for an investigation, but that is waived if it is coverred under warranty. He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #198119 1st Jan 2013 1:52pm
