Home > Td5 > LED Stop/Tail light issue.
SteveG
2005 Defender 90 Td5 CSW Belize Green
LED Stop/Tail light issue. I installed Le Perei LED lights, all worked ok with ignition off and lights on. Tail light on and brake lights up when you press pedal. However,with engine running tail light works ok, but when you press pedal lights go off rather than show brake light.
Any ideas?? Do I need to install a different relay for stop/tail circuit?
Thanks
Steve
Post #197619 30th Dec 2012 8:48pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
We're the connectors already on the lights? I would look at them first. Changing to Led shouldn't cause a problem, I did mine at the beginning of the year on my TD5 without changing anything.
Post #197622 30th Dec 2012 8:54pm
