Home > Puma (Tdci) > Running rough and wouldnt rev |
Aäron Member Since: 26 Oct 2010 Location: Sedella Posts: 27 |
For some reason the engine was in limp mode.
I had the same after my turbo hose was blown off and i put it back on. After a restart it was good. Is the engine light burning? |
27th Dec 2012 7:49pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
Hi, the engine management light wasnt on and the temp guage was normal, and yeah after a restart it was perfect
27th Dec 2012 7:54pm |
27th Dec 2012 7:57pm |
anyone! NO ROAD..........EXCEPT FOR LANDROVER
28th Dec 2012 6:49pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Can you give us a bit more history please?
What is the mileage, have you owned it from new and have the glow plugs ever been changed, did the glow plug icon on the dash light up? Do you have a DTC reader and if so where there any logged? Did you notice the exhaust plumes colour and if it was smokey or not? What about the Ambient air temp when the fault first occurred? How much fuel was in the tank and where did you fill up last? Any issues with water ingress into the cab? Have you been through any deep puddles lately? This list is not endless so any extra information you can provide will give us all a bigger picture to explore, Cheers Brian. |
28th Dec 2012 8:04pm |
answers, answers! mileage is 62000, bought it second hand, glowplug light came on with ignition, then went out as usual, yes ive got a DTC reader but never thought to check for any codes no more smoke than normal, air temperature was approx 7-10 degrees, tank was full of esso juice, no water in the cab, maybe an odd puddle or two, but no deep ones. the engine management light wasnt on. it was perfect this morning on the way to work and perfect tonight coming back. thank you, Harry NO ROAD..........EXCEPT FOR LANDROVER |
28th Dec 2012 9:41pm |
also checked tonight if there was any DTCs thrown up, and there was none out of the ordinary. NO ROAD..........EXCEPT FOR LANDROVER
29th Dec 2012 6:32pm |
well the solution ive come up with is that ive had a tank full of diesel. i drained about 1/4 of a pint out of the filter into a clear pot, and the amount of crap that was floating about in the bottom was unbelievable so i used the rest of the tank up. the filled her up with v-power and......touch a bit of wood, shes never missed a beat since NO ROAD..........EXCEPT FOR LANDROVER
18th Jan 2013 7:26pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
I had some thing simmilar happen to mine when away in Nottingham on a course - did a bit of city driving for 2 weeks, short runs, stop start, not letting the engine warm up ...then let it sit in the cold damp air
The engine was running very rough, no power or acceleration, lots of white smoke. Took it for a long run and no improvement.. I though the EGR was on the way out again Added a quality EGR and injector cleaner to the less then half full tank and it was sorted witn in 50miles ... ! back to full power and full acceleration. Cost was about £7 for the cleaner but well worth it - I'll be adding this to the fuel every 3 months just to keep the engine clean. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
18th Jan 2013 9:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20436 |
Can I ask what it was you used pleased? Would be interested to know. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
18th Jan 2013 10:24pm |
Hi Steve,
I'm not sure what it was called as it was recomended by a tame mech ... I'm at work at the moment so cant get to see what it was so will pop in and see when home next time I do know it coverd cleaning both injectors and EGR's .... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
19th Jan 2013 6:36am |
