Home > Maintenance & Modifications > Door theft protection, |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
didn't know this doubled as a f*** buddy site !! I used 5mm BB's Guns and Landrovers .... anything else is irrelevant. |
27th Dec 2012 2:56pm |
orhdpos Member Since: 03 Dec 2012 Location: Hoddesdon Posts: 8 |
Part of my layered approach, I've brought some of them scaffold eyes the things that secure scaffold to a building, well they are rated to take 1250KG and have M18 fitting a few of them in the garage concrete floor for ground anchors and a couple more in the lintel to take scaffold tube which you slot up and drop into 50mm dia holes in the concrete floor, secured with a couple of padlocks so they cant be removed, means landy cant be move from the garage without going through scaffold tube or cutting pad locks, and secured underneath with ground anchors, thing is you can pick them up with a fixing for about £15 each so 4 £60 cheaper than a purpose made ground anchor, you have 4 things to be cut through hard to use a angle grinder under a lany in a confined space like a garage.
It all helps Orhdpos |
27th Dec 2012 6:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
As part of a layered approach that's a good idea. I suggest stuffing a length of rebar down the scaff tube and filling it with concrete, since it would be easy enough from your description to cut the tube in well under a minute without a sound. With concrete and rebar, it's still under a minute but noisy. A 4.5mm ball will fit fully in the recess in the screw head. A 5mm won't bottom out but might go in if you belt it! |
27th Dec 2012 7:06pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Thats a cracking idea k9f
i will have to get some bb fitted once i have stainless screws fitted 2004 TD5 Defender 90 xs station wagon |
27th Dec 2012 7:30pm |
Thanks but before you ask how big my balls are here's a picture to satisfy anyone's curiosity..... Google 'big balls' and there's pictures there that will give you nightmares for weeks.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Dec 2012 9:48am |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I decided to fit heavy duty security posts, the front one is telescopic and the side post that boxes the landie in is a lift out post. Doesn't prevent door theft though...
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
31st Dec 2012 1:19pm |
I clicked on one of those youtube links, I knew I shouldn't have but you know what curiousity is like. I am traumatised but as you say I only have myself to blame |
31st Dec 2012 1:27pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
That ford looks pretty vulnerable though.
31st Dec 2012 1:28pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
I use a post and another vehicle to block mine in
31st Dec 2012 1:35pm |
YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 206 |
Is the red top part of the security system too? Electrified gates perhaps? 2013 Defender 110 XS DCPU 2016 Ford Mustang 5.0 V8 |
31st Dec 2012 2:59pm |
Your right, but I couldn't care less about the Ford as its a company car. And it's not mine |
31st Dec 2012 4:23pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
A 4.5mm ball will fit fully in the recess in the screw head. A 5mm won't bottom out but might go in if you belt it![/quote] Sometimes it's better to let the inner bar / tube to spin and be free moving as when some tries to cut it, it constantly turns making cutting far harder as it jams the blade It's what I did on my window guards on my van It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
31st Dec 2012 4:33pm |
Click image to enlarge Nicking doors is perhaps not a new thing... |
2nd Feb 2014 11:13am |
