Home > Puma (Tdci) > Puma Defender cutting out |
pegroundworks Member Since: 26 Dec 2012 Location: Halifax Posts: 1 |
Hi All
Found the forum after a fortnight of pulling my hair out. Have a 2008 SWB Van. After numerous electrical problems from new it started stalling three weeks ago cutting out at random times and running rough. After spending another two weeks at LR dealers presenting no ECU faults and them scratching their heads we seem to have found the fault. On Monday they replaced a fuel pressure sensor (despite it not showing any faults) and this seems to have fixed it. Touch Wood !! Will update with any changes but hope someone can find this useful as it has quite frustrating not being able fix it with constant replies of "the computer says its ok !!!" Peter mail@pegroundworks.co.uk www.pegroundworks.co.uk |
27th Dec 2012 11:00am |
Landscope Member Since: 23 Nov 2013 Location: Cumbernauld Posts: 8 |
Hi All I have a very similar problem in my 2008 130 that I just purchaced.
Picked it up and drove it 65 miles of the 180 to get home and it started cutting out about every mile.... joined the aa at the roadside they checked it and wanted to recover it the 120 miles home for more money...... managed to nurse it home by coasting along hard shoulder when it cut out!! got it into my local independent specialist who have changed two different fuel valves (£130 and £150 parts so far)and its not much better!! So far its cost £500 in garage fees and £150 in aa membership!! now the garage want to put a fuel pump on it to see if that makes it better!!! any ideas or help Please!! Thanks Brian |
23rd Nov 2013 2:05pm |
Joseph Nambudyie Ouma Member Since: 24 Nov 2013 Location: Kitale Posts: 1 |
Dear all kindly have come a cross to about five puma my 2007 with the same problem when overhauling the engine you find that the inlet valve are worn completely What could be the major problem
24th Nov 2013 6:04am |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
For inlet valve you mean the so called Volume Control Valve embedded in the pump body ?
24th Nov 2013 7:34am |
