Home > Puma (Tdci) > Strange 'hiccup' at just under 2k rpm?
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
My 09 puma has got a little fault developing, I've noticed a hiccup if you accelerate gently from around 1500 to just over 2k. For example if your crawling in 1st or 2nd in traffic and the traffic moves on, if I gently accelerate up the car sometimes violently hiccups from the engine like a surge. It doesnt happen if you accelerate hard only if your crawling along, It's really strange and hard to describe! I had a similar fault on my old astra diesel and was told it was the egr valve, is this so on my defender? It's done 29k and is a 90 2.4 tdci
Cheers! Smile 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #196487 26th Dec 2012 11:50am
bell-auto-services
It could be the egr or the turbo vains sticking slightly when hot. It could be other things but I'd look here first.
Pete
Post #196496 26th Dec 2012 1:29pm
Jimbob
funnily enough I just emailed you pete! about the remap interface. I dont like the sound of the turbo vanes sticking, sounds expensive! Is this common? how can I eliminate that?
cheers Smile 2009 Defender County Hard Top (gone 😞)
Post #196498 26th Dec 2012 1:33pm
I would say it's the EGR playing up a bit. My last one was knackered and it had odd effects. Fitting a brand new one was like having a new 90! As it's de-grading you tend not to notice but when it's working as it should you can straight away. But only when replaced. Neutral Often a lack of true performance I found too. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #196499 26th Dec 2012 1:35pm
Jimbob
Hmm ok that sounds about right thanks! hopefully I want to shut it when I get my truck remapped with the interface if it can be done as every car I have ever owned with an EGR on it has given me trouble! bin the damn things I say! haha Smile 2009 Defender County Hard Top (gone 😞)
Post #196500 26th Dec 2012 1:38pm
I agree they are a PITA! I found when my old one was having issues I felt like I had to drive on the power all the time but getting no where fast. With the new EGR fitted it's just as it always should have been. That said it was warning me by putting up the MIL on the dash so it wasn't undetected. I found the early signs of it giving out was it "chattering" on idle. I don't know how handy you are with a spanner / what tools you have available but if you did go down the replacement EGR route with a bit of awkward fettling and a free day you could do it yourself.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #196502 26th Dec 2012 1:43pm
bell-auto-services
Most of the turbo vanes only stick when the turbo is really hot after a good run or giving it some stick. If you take it for a hard drive for about 30 mins and then within about 3 mins of stopping the engine remove the circling from the turbo actuator you can sometimes then get hold of the arm that controls the turbo vanes and actuate it you may feel them sticking.
After a further few mins with the engine stopped they free off. This test is only good when the car is fully up to temp and had some hard work. As said you must test SOON after stopping the engine or it will free it's self.
Some people with the speed limiter removed can still only just get to 85 mph we have seen this in some cases be caused by the turbo sticking.
This may not be your problem but worth a test none the less.
Pete
Post #196506 26th Dec 2012 2:02pm
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
Jimbob, did you find the solution to your problem??
Tim
Post #384686 4th Jan 2015 12:12am
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
I'd really appreciate a feedback on this too, as I'm having a very similar problem, described in this thread: http://www.defender2.net/forum/viewtopic.php?p=384685#384685 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #384700 4th Jan 2015 12:52am
