Home > Maintenance & Modifications > Gutter advice - LR not house !!
bob neville
Hoping to cure the wet knee syndrome in the 90 as it has quite a few cracks in the gutter seal, some about 2" long but very thin. Rain gets into the inner gutter and I get soaked the first time I put the brakes on.
Do I just try and seal them or am I best to dig the old seal out and replace with Sikaflex - cue K9F Rolling with laughter
I have also got to do the join over the roof where the previous little old lady owner kept going under height barriers which were to low.
I think that getting rid of the old seal and putting a new seal in is probably going to be best, do it once do it properly, but any advice appreciated Thumbs Up
I have fitted new door seals and sorted the alpine windows out so the gutter and roof join are the last two areas to be done.
Ta
2013 Defender 90 CSW - sold
Post #196271 24th Dec 2012 5:26pm
GUM97
A few posts here ( www.defender2.net/forum/topic15827-15.html ) may be worth a read about the gutter sealing.... An engine to TDi for!
Post #196275 24th Dec 2012 5:31pm
Bob
have a look at the seal above the windscreen. for an experiment, run a band of petroleum jelly or similar along the length of the joint above the windscreen, pop some newspaper in the channels next to the alpines to soak up any residual moisture.
leave in the rain (if we ever get any Rolling with laughter ) i found that seal the most difficult to fix.
the other unusual area is where the gutter arcs around the back door in the corners, make sure they are fully sealed. it took me about 6 months to fix my old td5 but it's worth it .. no more cold showers.
If I were to do it all again and I had the space, I'd take the roof off and re-fit - probably the quickest and most thorough way
cheers
steve
Post #196278 24th Dec 2012 5:36pm
bob neville
Thanks GUM Thumbs Up
Saw that one but to be honest I have never got on with Captain Tolley's hence the reason why I am looking at digging the old mastic out and replacing it.
I did force some Dum Dum into some of the cracks as per other posts, it helped but as there are so many of the little devils I thought a proper job would be easier ?
Post #196281 24th Dec 2012 5:39pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi,
A friend has used Captain Tolleys Creaping Crack Cure on an old caravan with great success http://www.captaintolley.com/
I reckon I would give it a go if I needed to stop a leak.
Steve
Post #196284 24th Dec 2012 5:40pm
bob neville
Thanks Steve (BPMAN version) Thumbs Up
I saw your post about the gutter over the rear door. Can't see any problem there but having said that I have only just found a three inch crack between the roof and gutter by the drivers door Shocked
Thanks the other Steve, maybe I should get some CT's and try again, at least it will be quicker than digging the old seal out. If it solves the problem then I could do a proper reseal when the better weather arrives, 202..... Laughing
Post #196288 24th Dec 2012 5:46pm
VeeTee
Netherlands
I used Sikaflex on the seams and in the gutters before I painted the roof last year.
I had a lot of water pooring down from the inner gutters before, but now I only have a very small leak left somewhere, I suspect the rubber from the alpine windows or the windscreen upper seal. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #196294 24th Dec 2012 5:56pm
bob neville
Thanks Vincent Thumbs Up
Did you remove the old mastic from the gutter before putting the Sikaflex in or did you put it over the old stuff ?
Post #196296 24th Dec 2012 5:59pm
VeeTee
Netherlands
Bob
No, did not remove it, but gave gave it a good clean, degrease, sanding, cleaning and degrease again before putting the Sikafex in. Cheers, Vincent
MySite
Post #196301 24th Dec 2012 6:10pm
bob neville
Thumbs Up
Happy Christmas !
Post #196303 24th Dec 2012 6:19pm
VeeTee
Netherlands
Succes with the repairs, and
Happy Christmas too to you all! Thumbs Up Cheers, Vincent
MySite
Post #196305 24th Dec 2012 6:21pm
