Home > Td5 > ECU wires |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 |
The electrical circuit diagrams are freely available in PDF form via google. You'll need to download pre or post 2002 as they changed from 2 track to 3 track in MY2002 IIRC
Cheers Steve |
20th Dec 2012 7:09am |
simon119 Member Since: 05 Apr 2012 Location: SG11, Herts Posts: 40 |
PM or text me your email address and i'll send it over
20th Dec 2012 9:09am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 |
Text sent Andy |
20th Dec 2012 8:54pm |
Ok been looking into this, and if someone can confirm or correct
Black ECU plug. ECU pin 12 - white green - pedal connector F - sensor 1 ECU pin 36 - white grey - pedal connector K - sensor 2 ECU pin 26 - black yellow - pedal connector D - earth As above - black yellow - pedal connector G - earth ECU pin 20 - red green - pedal connector C - unknown ECU pin 14 - white purple - pedal connector B - supply 5v As above - white purple - pedal connector J - supply 5v Any help much appreciated Andy |
21st Dec 2012 11:47am |
