Home > Maintenance & Modifications > Heated Seats and Windscreen.
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Ok, So I recently got a tax rebate. I've got two choices... stick in the bank, or spend it. Then two choices of where to spend it - somewhere sensible, or on my Land rover.
No really no choice at all Laughing
I want to fit a heated windscreen and heated seats, want to do the work myself to keep costs low (I was a mechanic for a while so I'm competent, if clumsy). Does anyone have any advice on keeping the installation as original looking as possible? I want to use original switches to fill some of the blanks in my dash if no other reason!
Post #194771 18th Dec 2012 10:15pm
Porny
Site Sponsor
Screen is easy....
http://www.mobilecentre.co.uk/index.php?ma...cts_id=576
From Tim (site sponsor on here).
And I'm sure Tim could make up looms (using correct plugs) for the seats as well.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #194774 18th Dec 2012 10:20pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
There's a good description of fitment of heated seats here:-
http://www.defender2.net/forum/topic10705-180.html
cheers
simon
Post #194776 18th Dec 2012 10:21pm
Retroanaconda
By most accounts fitting the screen yourself, while not difficult, can be a bit of a lottery. Often they break on fitting, which isn't so bad with a £30 normal screen... but a £150 heated one would be a bit sore!
I've done one screen, got away with it. Not sure I'd risk a heated one unless I got it cheap. Use plenty of lube!
Or pay a fitter to supply/install one, that way they're liable.
Post #194780 18th Dec 2012 10:37pm
Welshsurferdude
Wales
I had chip in the screen so phoned up my windscreen cover, they asked if heated or not and so naturally i said heated and they fitted a heated screen in for £50 Very Happy
all I have to do now is wire it in which i havent bothered as yet! 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #194782 18th Dec 2012 10:45pm
appaloosadude
I've had a look at both those posts mentioned here, while I don't doubt the quality of the Mobile Centre kit, it does seem a little expensive for what's there. Also, I should've mentioned, I'm looking at aftermarket seat heaters to fit at the same time as I retrim the interior
Post #194783 18th Dec 2012 10:47pm
appaloosadude
Got a mate who is a windscreen fitter, couple of beers and he's happy Wink
Post #194790 18th Dec 2012 11:12pm
Retroanaconda
Even the pros break them, that's why I suggested getting someone to supply/fit - that way if they break it they pay for it! It's an easy enough job to do with a bit of string and some lubricant, it's just the risk of busting it one has to take into account Smile
Post #194791 18th Dec 2012 11:15pm
mobilecentre
Buy the relay here http://www.mobilecentre.co.uk/index.php?ma...cts_id=566
Plug & Switch here
http://www.mobilecentre.co.uk/index.php?ma...cts_id=575
These are the main parts if you are looking to save a few quid and put it together yourself instead of paying us to do it Thumbs Up
Post #194807 19th Dec 2012 12:22am
WarPig
Got my wiring kit from mobilecentre, does the job perfectly. Got an auto electrician to connect it up though as I havent got a clue. Then fitted a mud stuff console with carling switches.
Post #194810 19th Dec 2012 12:37am
mobilecentre
Just as an FYI it may look a little expensive for what is there but if you buy all the electrical parts from VWP it comes to a few pence short of £50 + VAT, then you have the genuine switch and connector at £15 so total parts cost to buy in would be at least £65 + VAT
The crimp tool to do the terminals in the LR switch is £400 + VAT Rolling with laughter Rolling with laughter Rolling with laughter
Once you get into what actually goes into a kit it is quite suprising Thumbs Up
Post #194813 19th Dec 2012 1:09am
appaloosadude
I'll think I'll stop being cheap and just buy the damn kit already! Good points, well made.
Post #194836 19th Dec 2012 10:09am
mobilecentre
To be honest it sometimes suprises me how much a few bits of wire can cost!
Post #194837 19th Dec 2012 10:14am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
For those looking for an entirely factory fit, I recently found a complete XS loom on ebay for £90... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #194838 19th Dec 2012 10:15am
Happyoldgit
I did a write up some years ago on how the pro's replace a screen, you'll find it here....
http://forums.lr4x4.com/index.php?showtopi...windscreen
I've personally replaced a number of Defender screens and while the job is far from difficult and can be carried out by someone without experience it's easier with two people, it's even easier to slip an experienced fitter a bit of beer money to do the job for you. If you are going it alone having the screen out gives you a good opportunity to deal with any corrosion found under the screen rubber. Steve.
Post #194840 19th Dec 2012 10:19am
