![]() | Home > Td5 > Another "won't go into gear" thread |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Sounds like your clutch is not disengaging. So would look at cylinders, and fluid, or just change both cylinders as they aren't costly.
Andy |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Could also bethe clutch fork on the way out - a reinforced version is available if you have time to source one...
Definitely sounds like something clutch related. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
I did not think that the clutch fork was an issue with the Td5, thought that was Tdi's
Andy |
You may well be right - I've not had one apart. My blog - www.anacreinhampshire.blogspot.co.uk
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I would start by bleeding the clutch hydraulic system through it may well have air in it. 2005 Td5 90 XS
Steve |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Td5 has the same fork as the V8, and it's a huge great hulking cast thing.
Funnily enough i've got the same problems with my project90... just dropped the engine in, brand new clutch, and it's dragging like yours is. I've adjusted the pedal-push rod as far as i can, and the bottom stop, but to no avail, so think i'll have to pull the engine out to sort it. ![]() |
Setok Member Since: 16 Jan 2009 Location: Helsinki Posts: 422 ![]() ![]() |
I'll let you know when there's an update. It's now at a garage. In the summer I would've been happy to try to adjust the pedal, or to attempt my first go at bleeding, but without knowing if that would make any difference I didn't fancy standing in the very windy, freezing blizzards we are getting in Finland right now!
I hope it is nothing big and can be sorted before Xmas, as otherwise our plans will become rather tricky... Typical too: it's perfect Landy weather. Thick snow everywhere. Parking spots readily available due to snow banks ![]() |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
I had similar problems, turned that the lock nut had worked loose and too much play on the push rod. found this out after bleeding system and then changing clutch fluid, at least that doesn't need changing for a while.
Hope that helps. |
Mud Dog Member Since: 11 Jul 2013 Location: Kent Posts: 31 ![]() ![]() |
So What was the result? I've got what seems to be the same problem with the 90 I just bought ![]() |
