Home > Puma (Tdci) > Blow dry your hair in a Puma |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Bob most of us don't have hair, you'll be putting your rollers in next NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
2nd Dec 2009 9:04pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 296 |
Can you get plug in rollers for the cigarette lighter? I was blow drying me hair outside work this morning, chatting away to an Irish gent on bluetooth chatting away about nothing in particular, so if i could stick the rollers in and have a smoke at the same time, then that'd be great! I bought a few tescos value pot noodles tonight at 9p each with an idea to sticking the pot in the unused plastic hole over the Puma engine and filling it with water to see if it cooked by the time i got to work. It's a very useful motor the Puma.
2nd Dec 2009 10:00pm |
You crack me up Bob, PS let me know about the pot noodle situation NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
2nd Dec 2009 10:13pm |
Tomorrow I want another one Bob!!!! The best way to start the fu@king work day Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Dec 2009 6:57am |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Funnily enough bob I did the very same last night. Girlfriend is 40 minute drive and I was rushing out with wet hair.
BUT the opposite happened to me Remember the Hamlet advert with the photo booth and comb over That was what I came out like 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
3rd Dec 2009 12:02pm |
You're obviously not using the rotating fascia vent control properly. I rotated it 180 degrees today so the vanes are horizontal, and it was even better. If you're quite a shortish sort of person, sit on the cubby box, and then you can use the rear view mirror for the perfect style effect, and the cubby is so useful to store all the essential hairdressing supplies in.
3rd Dec 2009 1:13pm |
3rd Dec 2009 3:26pm |
Pot Noodle pots are too tall, you can't get the bonnet shut! However pop in a haddock, knob of butter and half a pint of water and after about 30 minutes lightly poached haddock mmmmmm! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Dec 2009 4:01pm |
